H4 High beams ?
Author Topic: H4 High beams ?  (Read 1346 times)
Offline TRIPLE-GREEN
    • Coupe Custom Accessories
H4 High beams ?
« on: April 07, 2009 - 07:04:58 PM »
Ok, just converted over to the H4 low beam lights and I am concidering doing a coversion to the high beams. What do I look for when it comes to bulbs. Do they offer an H4 with 2 progs? My low beams are 3 which was no problem but my hi beam plug is 2 prong. HELP???  :1zhelp:   :clueless:
Re: H4 High beams ?
« Reply #1 on: April 07, 2009 - 08:34:44 PM »
I ask the same question some time back...the solution is only hook up two wires.
Re: H4 High beams ?
« Reply #2 on: April 07, 2009 - 09:03:48 PM »
do they not offer a 2 prong H4 bulb for high beam ?
 if not just bend the 3rd tab out of the way & connect the 2 prong plug , you onmly want it on with high beams anyway
Offline rusty dodge
  • 74 challenger 440-727-3:55
Re: H4 High beams ?
« Reply #3 on: April 08, 2009 - 05:34:44 PM »
H1 bulb is the high beam by itself.
http://www.rallylights.com/detail.aspx?ID=137
Re: H4 High beams ?
« Reply #4 on: April 08, 2009 - 06:07:57 PM »
I figured they would have to make one for high beam only
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
Re: H4 High beams ?
« Reply #5 on: April 08, 2009 - 06:23:02 PM »
Or run the low and high on all 4 lights  :rofl:
Go Fast & Have Fun...
Re: H4 High beams ?
« Reply #6 on: April 09, 2009 - 12:06:46 PM »
I would, but I fear that I am already taxing the charging system. I am about to get a 80 amp alt. Just to replace the stock one. I assume that 80 amp is higher then the stock alt. Am I right there?
   With hopes that it will be ok. I want to put in a headlight relay but I am a  :clueless: when it comes to electrical. So I don't want to  :eek4: it up.
Re: H4 High beams ?
« Reply #7 on: April 09, 2009 - 02:56:16 PM »
You need to change to headlamp relays if your running that high of a wattage bulb, get the load out of the old harness & swith. & think about udating the newer Denso alternator.
You can find good info on Goodys web page.
Goodysgotacuda.com
Re: H4 High beams ?
« Reply #8 on: April 15, 2009 - 06:12:32 PM »
I was thinking about redoing the complete headlight harness Like Goody did. Where does it detach? I was going to pull the old one and build a new one with the relays. Any help would be great!!
Re: H4 High beams ?
« Reply #9 on: April 15, 2009 - 06:29:05 PM »
At the firewall bulkhead connector below the brake master cylinder
Offline GoodysGotaCuda
Re: H4 High beams ?
« Reply #10 on: April 15, 2009 - 09:01:27 PM »
There is not a factory "headlight only" harness. Like mentioned, it is entwined with many other circuits.
1976 Dodge Warlock
Wheel & Tire Specs:Link
