I am putting together a '72 Challenger that has Front Disc brakes from a '74. I have the proportioning valve that inline tube says is for 70-72 with drum-drum or disc-drum. I also have brand new SS Lines installed. The problem is the fittings on the new lines do not fit the valve where they are supposed to go! The fitting on the line to the back brakes is too big for the hole in the valve and the fittings on the lines that go to each side of the front are too small for the valve!
Do I have the wrong valve?
Do I need the '73-'74 Valve?
Thanks!
Jeff
