Author Topic: How to id a rallye harness  (Read 666 times)
Offline priderocks
« on: April 08, 2009 - 07:54:15 PM »
What is the most obvious way to identify a rallye harness? I have two harnesses, and neither will connect to a wiper switch #2770380 which is supposed to be a variable speed wiper switch. The harnesses do not have plug-in 4 bulb harnesses for a rallye light bar, so I can't tell that way.
The correlation between the wiper connector and rallye harness is confusing me. Are there two different rallye harnesses, one for two-speed wipers and a seperate harness for variablespeed wipers?
Re: How to id a rallye harness
« Reply #1 on: April 08, 2009 - 08:57:15 PM »
Yes I believe the plug is different although the wires are the same , rally harnesses have the single connector grey wire to the tack
