Author Topic: Cam Question  (Read 1589 times)
sleepychallenger
Cam Question
« on: April 09, 2009 - 09:11:43 AM »
I am looking at the VooDoo cams, any input on if they are good or what size i should get for the 438 build?
nivvy
Re: Cam Question
« Reply #1 on: April 09, 2009 - 09:30:09 AM »
I like the voodoo cam line.... what style cam?
Re: Cam Question
« Reply #2 on: April 09, 2009 - 10:22:53 AM »
VooDoo or Engle are great cam grinds , the type depends on what you want the engine to do
 how long is a piece of string LOL
« Last Edit: April 09, 2009 - 08:01:51 PM by Chryco Psycho »
sleepychallenger
Re: Cam Question
« Reply #3 on: April 09, 2009 - 10:44:01 AM »
my goal is 500 hp or close to it. 10:1 compression. want something that i can still run a brake booster and drive down the road. all of this is budget build but there are some areas that will be saved up for.
nivvy
Re: Cam Question
« Reply #4 on: April 09, 2009 - 11:08:06 AM »
hydraulic / solid or roller ?
Ebay has voodoo mopar cams all the time on there....  :working:
Offline moper
Re: Cam Question
« Reply #5 on: April 09, 2009 - 01:19:17 PM »
refresh us on what you're building... be specific.
sleepychallenger
Re: Cam Question
« Reply #6 on: April 09, 2009 - 02:33:12 PM »
specific is dificult. i am planning a hydraulic cam
i am looking at a 438 Stroker
383 block
440 crank and rods
10: 1 pistons
still looking at head options and header options.
nivvy
Re: Cam Question
« Reply #7 on: April 09, 2009 - 02:54:46 PM »
I would go solid cam minimum....  :2cents: not that much more money either  :working: mopar .528 with 1.6 rockers ...
Also If you go aluminum heads higher compression is more HP and still run pump gas...
Header options find a good used quality set and have them sandblasted and repainted with 1200* heat paint and will look good as new....
« Last Edit: April 09, 2009 - 02:57:47 PM by StRoKer »
sleepychallenger
Re: Cam Question
« Reply #8 on: April 09, 2009 - 03:08:40 PM »
i was thinking of getting the 440 source heads. why the solid cam? does the voodoo come in the .528. why 1.6 rockers? I was thinking of getting a used set of headers and doing that.
if i go for a set up that is like this, do you think i will reach my 500 goal?
nivvy
Re: Cam Question
« Reply #9 on: April 09, 2009 - 03:47:38 PM »
Easily 500HP with unported stealths .528 lift will get you .561 lift with 1.6 rockers....
Offline moper
Re: Cam Question
« Reply #10 on: April 09, 2009 - 06:22:46 PM »
When you figure out gearing, heads, and details, then ask about the cam. Cam makes everything work together, or doesnt.
sleepychallenger
Re: Cam Question
« Reply #11 on: April 09, 2009 - 06:52:05 PM »
i am planning on running my same 323's with the A-833 4 speed. heads are going to be the 440 source stealth heads. not sure what other details you are looking for.
sleepychallenger
Re: Cam Question
« Reply #12 on: April 09, 2009 - 06:52:48 PM »
with that lift will i have to worry about piston clearance?
nivvy
Re: Cam Question
« Reply #13 on: April 09, 2009 - 07:59:14 PM »
sorry sleepy I thought your post when you meant 438 you were getting a stroker kit....  :working:
Re: Cam Question
« Reply #14 on: April 09, 2009 - 08:04:33 PM »
I use mostly UltraDyne solid grinds , I virtually always use solid cams now unless someone really wants a hyd cam
 we need to kno wwhat gearing you want to run , what tire size , what MPH you want to cruise at on the highway etc to determine where to put the powerband to work best
