Author Topic: Tach Question .  (Read 792 times)
Offline BadJoey
Tach Question .
« on: April 10, 2009 - 07:54:14 AM »
I am putting a 70 Challenger back together . I never had it when it ran . If I'm not mistaking the tach wire is gray with a black tracer .The question is where dose it hook up . the poss post on the coil ?  :burnout:
Offline the_engineers
Re: Tach Question .
« Reply #1 on: April 10, 2009 - 09:53:56 AM »
Most tachs hook to the negative post on coil.  I'll see if I can find my FSM.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Re: Tach Question .
« Reply #2 on: April 10, 2009 - 11:20:11 AM »
It hooks up to the "-" side of the coil. If you put more than 5 Volts on that wire, you will cook your tach.   :eek7:
Offline BadJoey
Re: Tach Question .
« Reply #3 on: April 10, 2009 - 01:44:33 PM »
Glad I asked . Than k you much guys . :bigsmile:
Offline BadJoey
Re: Tach Question .
« Reply #4 on: April 10, 2009 - 03:21:16 PM »
BOY . This really is GOOD FRIDAY ! The guy I bought the car from 30 years ago told me the tach didn't work . Well it WORKS now . Happy Day ! :cooldancing: :cooldancing: :cooldancing: :cooldancing:
Re: Tach Question .
« Reply #5 on: April 10, 2009 - 03:44:21 PM »
Way to go!!   :2thumbs:
Next, let's hope the tack is reasonably accurate.   :woo:
Offline BP23G0B
Re: Tach Question .
« Reply #6 on: April 16, 2009 - 12:23:13 PM »
For 15 years I've thought my tach was toasted.  After reading a thread about putting the signal wire on the "-" side of the coil, I decided to double check to see if mine was wired correctly.  I found it was hooked to the "+" side of the coil.  It sprang to life last month after I moved that one wire. :2thumbs:
If only more problems were that simple...
'70 Barracuda Gran Coupe
'14 Ram 1500 Express Black Edition
Offline CUDA JAS
  • vroooooom!
Re: Tach Question .
« Reply #7 on: April 16, 2009 - 04:05:31 PM »
Yeah I know what you mean.
I drove my car with no tach for three summers after I got it.
When I pulled out the gauges to do dome work, I found the dork that put in the rallye guages did not bother to hook up the tach.
74 'cuda 360/727
Just call me a gearhead!
