Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Suspension, Wheels/Tires, and Brakes
(Moderator:
Chryco Psycho
Tire pressure at the track
« previous
next »
Print
Pages: [
1
Author
Topic: Tire pressure at the track (Read 1060 times)
nivvy
Guest
on:
June 25, 2004 - 08:08:11 AM »
...Now since i will go only a few times ...should i have my psi at about 20?
and also if i have tight wheelwell tolerances do i have to worry about shredding a tire??? with lower pressure in the tires does it make the tire go closer to the spring/wheel lip? or does it only go closer with a lot of tire pressure?
Logged
BB73Challenger
Sr. Member
2 cars - twice the wrenching... yay?
Re: Tire pressure at the track
Reply #1 on:
June 25, 2004 - 09:54:15 AM »
Need more info like street tire or slick - also I've heard you don't want to go too low or you will just make your tire cup in the middle of contact area killing your traction ( also depending on HP and how much tire spin you have ).
Logged
Jeff from Cleveland, Ohio
Chryco Psycho
Administrator
C-C.com Guru
Reply #2 on:
June 25, 2004 - 01:15:18 PM »
I used to run 20 psi in the rear tires with a wide radial & about 40 in the fronts , generally the tire wil be wide on the sidewalls with less air
Logged
nivvy
Guest
Reply #3 on:
June 25, 2004 - 06:14:02 PM »
do you think the 325/50/15's bfg drag radial will fit??? or not even try....stick with the 295/50/15's or 275/50/15's?
Logged
360 'CUDA
Sr. Resident
Reply #4 on:
June 26, 2004 - 02:24:06 AM »
I have got to get me a set of these 325s you keep talking about
They sound cool
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
