Author Topic: dual to single ballast  (Read 765 times)
Offline Justins72
« on: April 10, 2009 - 09:55:03 PM »
I have upgraded my ecu to a chrome box with a blaster 2 coil and the coil calls for a .8 ohm ballast i was going to order one but its has the 2 pins instead of the 4 pins i have now. So how do i convert my 4 pin to 2? thanks
Re: dual to single ballast
« Reply #1 on: April 11, 2009 - 06:04:08 PM »
Just connect the blue & brown wires to the single ballast , the green red trace wire is eliminated
Offline 74 340 4speed
« Reply #2 on: April 11, 2009 - 06:59:29 PM »
I put one in a while back too.  Here is a picture to explain what Chryco is saying.
Your car will run better with this setup.  I noticed a huge improvement.
Andy
1967 Camaro SS: 406 sbc 505 hp/506 ft lbs|4 speed|Posi|3.73s
1969 C/10  350|Turbo 350
1969 Dodge D300 318|4 speed|Dana|4.88s
1972Nova: 350|Turbo 350
1974 'Cuda: 340|4 speed|Dana 60|4.10s|posi
1999 Camaro SS: Auto|Longtube Headers|True Duals|TT2s
2013 Challenger R/T: 6 speed|Hurst with pistol grip|mopar performance exhaust|super track pak
Offline ShelbyDogg
« Reply #3 on: April 16, 2009 - 02:25:02 PM »
74-340-4speed, it looks like your voltage regulator had a little meltdown. You may want to change it if you haven't already. The components use that dielectric sandy epoxy for anti-vibration and cooling. Your charging system may fail if that is now a bare board.
