Bullitt....
It looks like that right side panel has to be welded in, right? Looked at my rad support and the side panels are tack welded to the lower and upper cross pieces....
Not looking to go there right now I dont think......
So I think I am back to the 22".......I think...but.....still confused....
None of the auto parts sites I am visiting (Rock, Auotzone, Advance) have a 26" radiator as an option....let alone a 3 core anything.....My manual shows that 26" was available in the A/C cars with the 318 and 340....but no 22" for the 318.........it shows a 19" for an automatic car.....the 22" is listed for the 340 with 727....
My radiator opening measures 22 1/2".....Measuring the actual opening, now. ....24 3/4" between bolts ( Am I measuring correctly? ).....I am assuming that I am setup for a 22" even though the manual doesnt .
I figured if I could find the 22" in a 3 row and add a shroud I would be ok...
Fan wise I am even more confused....The manual lists torque and thermo clutches ONLY on the 340 car....just a 2.2" space for the 318....But again I assume I can use the thermo clutches that autozone lists for my car......right?
And fan-size wise, they list 3 different fans in the manul for the 318 --
-- 18" - 4 blade - 2" width (automatic)
-- 18.25" - 5 blade -- 2.31" width (a/c)
-- 18" - 7 blade - 2.25" width (high capacity)
For the 340 it lists the same fan -- an 18 1/2" - 7 blade - 2.5 inch depth fan for standard, manual and AC, with no listing for "high capacity"
Autozone, Rock, etc dont make any distinctions on the fan sizes.....
So what gives?
