Author Topic: Welded bumperbrackets  (Read 735 times)
Offline Belgium Cuda
  • Living in Belgium but beeing Swedish
« on: April 13, 2009 - 04:57:56 PM »
After taking a closer look at my challenger I see that the bumperbrackets on the front framerails are welded
in place instead of using the bolts, shall I suspect an accident caused this to be needed? :clueless:
How can I find out if the frame is unstraight?
1970 Challenger Convertible - to become a Hemi tribute
1968 Charger R/T 500 cui stroker
Offline dutch
Re: Welded bumperbrackets
« Reply #1 on: April 13, 2009 - 05:17:16 PM »
hey per,
I`ve got a shopmanual at home. It descibes all body and frame measurements. I can make a copy when you come over next weekend...  :2thumbs:
Bart
*** Bart ***
« Reply #2 on: April 14, 2009 - 03:00:43 AM »
Thanks friend :thumbsup: Just can't figure out why they did it. If I'm lucky it's because the bolts were brooken off. :grinyes:
Offline 72bluNblu
« Reply #3 on: April 14, 2009 - 03:16:57 AM »
Here you go!  ;D
Maybe somebody decided to tuck the bumper into the fenders more and didn't want to drill new holes?  :dunno:
« Reply #4 on: April 14, 2009 - 04:39:04 PM »
Thanks  :cheers:
« Reply #5 on: April 15, 2009 - 02:24:21 AM »
possibly there is no damage & the bolts holding the bumper were seized & could not be re-installed after reemoving them , you would have to cut the frame open & replace the nuts welded inside the frame rails , which you are probably now faced with doing
« Reply #6 on: April 15, 2009 - 03:02:02 AM »
When I start disassembly I will post some pics, first have to put my Charger -68 together.  :eek4:
