Author Topic: How long will this last?  (Read 1925 times)
Offline cudadave72
  • you motorboatin sob!!!
« on: April 14, 2009 - 10:09:33 AM »
I just dug up some info on the 71 Chally that has the 318 with twin turbos making an incredible 745rwhp at 18psi of boost. Talked to the guy that built it and he confirms it is a stock block. They wanted to use an R3 block but couldn't find one. That is freaking awesome for a 318 based engine, however I have to wonder how long this engine last before it blows apart??? :dunno:
1972 BS23 H code Cuda, B5 blue, 340 streched to 416 cu in, 727 w/ 8 3/4 rear, 7.23 in the 1/8 mile and 11.38@117mph in the 1/4 on drag radials   Under restoration! Coming soon... 440cuin R3 Indy SMALL BLOCK monster!!!!
Offline Oldschool
  • Member Since 9-05-06
Re: How long will this last?
« Reply #1 on: April 14, 2009 - 10:33:09 AM »
I would think that with forged internals and arp fasteners it should hold together quite well.  If it was making that kind of power with spray, not very long.  Spray "shocks" the engine and turbos apply power more smoothly, making it easier on the engine.  Just my   :2cents:
Ken  --  In Georgia
Offline cudadave72
« Reply #2 on: April 14, 2009 - 11:47:05 AM »
Thats good input concidering that I want to do a simular set up to my 340 stroker. He told me that system was around 15k! Being a mechanic and seeing that set up I believe I could build a simular system for under 5k. Looks very straight forward as far as turbo systems go.
Offline moper
« Reply #3 on: April 14, 2009 - 11:52:42 AM »
If the bores are thick, and some 318s are much thicker than they get credit for, it should last decently well. Turbo supplied boost is not very hard on internals compared to supercharging or chemical supercharging (NOS). The R3 would have had more meat in the mains and better decks for sealing. But if it was all done right, that's not a grenade waiting for the pin to be pulled.
« Reply #4 on: April 14, 2009 - 12:14:14 PM »
 :iagree:
Offline 71chally416
    • The Streetwalker
« Reply #5 on: April 14, 2009 - 02:38:47 PM »
The biggest problem is holding the heads on the block under boost with 4 head bolts. I didn't know there was a shortage of R-3 blocks   :clueless:
http://www.moparsupercenter.com/cast-iron-r3-race-engine-blockp4876792ac.html
http://www.monicattichrysler.com/comersus/store/comersus_viewItem.asp?idProduct=1010
moparniac
« Reply #6 on: April 15, 2009 - 06:46:10 AM »
That car is owned by blouch at blouch performance. bigtime turbo guy In PA  :2thumbs:
« Last Edit: April 15, 2009 - 09:57:44 AM by StRoKer »
Offline cudadave72
« Reply #7 on: April 15, 2009 - 03:37:05 PM »
Yeah I talked to Mike who works there. I'm conviced I'm going to do a turbo set up. Might stick with a single 76mm. That will be alot easier to do and will still make huge power. Not your kinda of power but good enough for me. :bigsmile: :bigsmile:
moparniac
« Reply #8 on: April 15, 2009 - 03:44:36 PM »
the stangs here where i live with 76mm turbos run 11.0's
GET A DANA 60  :bigsmile:
Offline dodge freak 2
« Reply #9 on: April 15, 2009 - 07:37:02 PM »
What about the casting webs by the main caps? Mopars are tought little motors but if its making an HONEST 745 REAR WHEEL HP what is that like 800 HP at the motor..come on. Common sense says something is going to break.
On a side note, I was surprise today to see my little 318 at 6500 rpms--and holding in third gear before backing off but its not making 400 HP I far as I can guess...some would say it is thou.
Offline HP2
« Reply #10 on: April 16, 2009 - 05:25:48 PM »
Who cares. As plentiful as 318s are, you just bolt another one up underneath the turbos and go.
Offline 71chally416
    • The Streetwalker
« Reply #11 on: April 16, 2009 - 06:35:52 PM »
Anything is possible I guess. I've seen the cylinders on several 360's collapse with far less HP and cylinder pressure than a Turbo car has. If and when it does give it up you just hope it don't dump a few gallons of antifreeze on the back tires at 130mph. Boosted cars car be unpredictable. I saw TWO of them barrel roll going through the traps at Cecil a few years back at the same race when they blew in high gear. A beautiful 60's box Nova and a fox Mustang. Both had Pro-chargers and were running the 10.5 tire class. The Nova looked like it came out of a car crusher when it went out on a flatbed. I doubt that the driver survived. That was just before they changed the rules and made them run 1/8 mile instead of 1/4. Probably a better plan would to start with a good race block. It makes little sense to plow machine shop money into an old stock block for an application like that when they are available. It will take out more than just the cheap engine block when it expires. :grinyes:
Offline ntstlgl1970
  • T a c o c a t
« Reply #12 on: April 16, 2009 - 07:55:10 PM »
There are some good threads on turbo builds at turbomustangs.com - they have a forum for mopars
http://www.theturboforums.com/smf/index.php?board=21.0
Some guys are making stock blocks live, I imagine that it is all in the tune....still sounds iffy making that kind of power with a stock block.
I agree with 71chally416 on investing all the machine shop money into a stock block for this application.
« Last Edit: April 16, 2009 - 07:57:31 PM by ntstlgl1970 »
Offline 71chally416
    • The Streetwalker
« Reply #13 on: April 16, 2009 - 10:46:21 PM »
Tryin to put all that HP through an old stock block is like building a house on a bad foundation. The basement will fill up with water at some point.  :2cents:
Offline cudadave72
« Reply #14 on: April 16, 2009 - 11:07:14 PM »
  :iagree:
