Author Topic: Saving a flood damaged engine and tranny  (Read 1265 times)
Offline whitesatinmopar
  • Member Since 3/30/02
Re: Saving a flood damaged engine and tranny
« Reply #15 on: April 15, 2009 - 08:59:43 AM »
Thats a lot of engines/lot of work and time. But for me I'd put each one on a roatating motor stand. Pull oil pans and heads, rotate to drain everything you can, spray with a combination of solvient and some kind of oil based rust inhibitor. Replace engine parts and fill with a light weight oil until it starts to come out of the plug ports, manually turn engine over. Unfortunatly in that cold damp enviornment it won't take long for rust to start.  I'd start with those 440's.  :2thumbs:  Good luck.
1969 Polara 500 vert.
1970 Charger 500
1971 Dart Swinger
1972 R/R 440+6 (wanabe)
1973 Challenger
Offline darkhawk
« Reply #16 on: April 24, 2009 - 10:24:11 AM »
Okay just an update on the work.  tried the slant 6 engine in my wife's valiant and drained about 3-4 gallons of water out before the oil came out.  For a minute there I thought I must have been a dumbass and drained the oil last fall and didn't add any.  Then I remembered oil is lighter than water, so it floated up to the top of the engine.  pulled the plugs, removed the carb, rad belts and hoses.  Added diesel into the intake till it came out the cylinders and then manually turned over the engine, drained everything and added oil.  Hope it works.  Gotta drop the tranny pan and change the fluid there next.  I think we will do the 440's and some of the 383's next, probably will not get to all, bummer.
Nigel
73 Cuda
65 Valiant Convertible
04 Dakota
Offline lemming303
  • San Antonio, TX
« Reply #17 on: April 24, 2009 - 05:51:55 PM »
I would suggest something other than diesel, water can suspend in Diesel. It happens in our trucks at work.
You might try adding some of that stuff that treats water in diesel to the diesel you are using. It may help, but I would find something other than diesel IMO.
Kevin
73 Challenger Rallye - first project
