Author Topic: Door lock rod  (Read 708 times)
Offline MR291
Door lock rod
« on: April 14, 2009 - 10:00:26 PM »
I was re-assembling the doors today, and had difficulty in getting the door lock rod to connect to the lock cylinder.  Is there a trick to this?  Do I need to unhook the bottom of the rod first to hook into the bit on the end of the cylinder? A picture would be great.
Thanks.
Offline 4 speed fish
Re: Door lock rod
« Reply #1 on: April 14, 2009 - 11:21:38 PM »
Are the cylinder locks reproduction?
Re: Door lock rod
« Reply #2 on: April 15, 2009 - 02:21:21 AM »
yes you need to remove the bottom of the rod from the latch , it is just pulls out of the nylon bushing in the latch , hook it back into the lock & pop it into the latch or you can remove the E clip from the back of the lock & reattach it to the lock after the rod is hooked in but this is harder to do
Offline MR291
Re: Door lock rod
« Reply #3 on: April 15, 2009 - 07:45:44 PM »
A bit of knowledge goes a long way.
Worked perfectly.
Thanks.
Re: Door lock rod
« Reply #4 on: April 16, 2009 - 12:52:36 AM »
 :2thumbs:
