Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
What is a Siamese block?
« previous
next »
Print
Pages: [
1
Author
Topic: What is a Siamese block? (Read 2392 times)
lemming303
Sr. Member
San Antonio, TX
on:
April 14, 2009 - 10:03:42 PM »
What does that mean? On an ad it says "Siamese block or resto"
Logged
Kevin
73 Challenger Rallye - first project
Moparal
Permanent Resident
Re: What is a Siamese block?
Reply #1 on:
April 14, 2009 - 10:04:56 PM »
Siamese cylinders are all joined together side by side. No water inbetween the jackets.
Logged
moparniac
Guest
Reply #2 on:
April 14, 2009 - 10:06:28 PM »
Quote from: Moparal on April 14, 2009 - 10:04:56 PM
Yeas ALAN is right.............
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #3 on:
April 15, 2009 - 02:33:33 AM »
to clarify the bores are linked between each bore adding stiffness to the bores , the water has to ciculate around the ends of the group of 4 bores to cool
Logged
lemming303
Sr. Member
San Antonio, TX
Reply #4 on:
April 15, 2009 - 12:18:15 PM »
OK that makes sense. So if you use this type of block do you need a stronger water pump? Does it effect the cooling efficiency of the engine at all?
Logged
Kevin
Ck[FIN]
Jr. Member
Get real - Get Mopar
Reply #5 on:
April 15, 2009 - 12:37:05 PM »
Stock water pump will work. Pistons could need more clearance when the block is honed to specs?
Logged
lemming303
Sr. Member
San Antonio, TX
Reply #6 on:
April 17, 2009 - 11:26:09 AM »
Cool, thanks yall.
Logged
Kevin
moper
Resident
Reply #7 on:
April 17, 2009 - 12:10:54 PM »
The 440 Source block
JK.. what they said.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
