road lamp pic request
Author Topic: road lamp pic request  (Read 863 times)
« on: April 15, 2009 - 12:17:38 PM »
I need to see a pic where the road lamp switch goes on a 70 cuda and where the relay installed. I believe the switch is on the left and down low and the relay is to the right of the steering column. Also what area it comes through the firewall with a 4 speed trans.  I got it all working and was installing yesterday but noticed my lower metal dash may not be drilled for lamp switch. The switch did fit where the shaker handle goes on the right tho. Any help would be nice
 :picture:
Offline 67vertman
  • Member since 9-23-2005
Re: road lamp pic request
« Reply #1 on: April 16, 2009 - 09:16:55 PM »
Bump...... :bigsmile:
I would like to see this as well.  I know there are plenty of people on here who have road lamps... :dunno:....can someone help a couple of brothers out?
Offline Slotts
« Reply #2 on: April 16, 2009 - 10:02:41 PM »
Here are two non Rallye switch panels that had road lamp switches. I believe the Rallye switch panel lands in the same position.
I will check the Rallye panel position and let you guys know this weekend.
I hope this helps.  :2thumbs:
Slotts
Offline 67vertman
« Reply #3 on: April 16, 2009 - 11:03:23 PM »
Thanks Slotts!  :2thumbs:
You’re AutoCadd (Computer Drafting) skills are excellent.   :poopoke:
Offline Slotts
« Reply #4 on: April 17, 2009 - 05:54:46 PM »
He don't know me velwe well, do he?  ;)
Offline 67vertman
« Reply #5 on: April 17, 2009 - 08:53:13 PM »
Show off!  Great works Slotts.
Offline Slotts
« Reply #6 on: April 23, 2009 - 08:57:09 PM »
Sorry for delay. This is a friend's car that he just picked up. There was no need to measure where the hole is located via measurements because it is a factory drilled hole in the frame. The switch to the right is obviously aftermarket with some nice aftermarket wiring underneath that has to go.
Hope that helps guys. :2thumbs:
Slotts
