Author Topic: 355 RATIO  (Read 3227 times)
Offline 383DART
355 RATIO
« on: April 15, 2009 - 02:01:42 PM »
i have a 1972 cuda 340 4 speed. it has a 355 sure grip. most of the dodge & plymouth scat pack cars with 904 or 727 auto had 323 sure grip.was 355 with a 4 speed standard equipment rather than a 323 sure grip. thank's. :feedback:
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
Re: 355 RATIO
« Reply #1 on: April 15, 2009 - 02:50:42 PM »
standard for the 4 speed cars (non dana of course) was 3.23 open with 3.91 suregrip an option or 3.23 suregrip. I believe from 72 on 3.23 was the lowest factory gear in a passenger car.
1996 Dodge Viper GTS Coupe
Re: 355 RATIO
« Reply #2 on: April 15, 2009 - 04:18:31 PM »
I would be shocked if 3:55's were put on 72-74 E-bodies. I think someone put those gears in there from an earlier year car.
Re: 355 RATIO
« Reply #3 on: April 15, 2009 - 04:33:00 PM »
Bullitt99's car is a 73 rallye  and it has a 340 with 727 and factory 355 single trac.
Offline 360 'CUDA
Re: 355 RATIO
« Reply #4 on: April 15, 2009 - 05:30:51 PM »
Hi 383dart
what is the number on the case?  Is it 741 by any chance?
Offline 73EStroker
Re: 355 RATIO
« Reply #5 on: April 15, 2009 - 10:34:36 PM »
My 73 340/4spd Chally had 3.55 standard with 489 SG
Barry (Salmon Arm)
Offline 383DART
Re: 355 RATIO
« Reply #6 on: April 17, 2009 - 12:11:56 PM »
Hi 383dart
      THE CASTING # IS 2881489.
Offline 360 'CUDA
Re: 355 RATIO
« Reply #7 on: April 17, 2009 - 02:18:19 PM »
Ok so you have the correct case.  The option code (D56) is listed for Mopars with 3.55:1 gear ratios from 1969 to 1974. If you could come up with a broadcast sheet for that car and find that code on it you would know for sure.
Offline 71chally416
    • The Streetwalker
Re: 355 RATIO
« Reply #8 on: April 17, 2009 - 02:58:51 PM »
I've seen both a '73 Chally auto and a '73 Cuda 4 speed with stock 3.55 gears. My '71 has them too (OEM gears) but I'm not sure if they were stock. They seem to have been used in small block cars more than the big block cars that usually had 3.23's.
Offline ted
  • 74 cuda, 70 challenger r/t
Re: 355 RATIO
« Reply #9 on: April 17, 2009 - 04:52:26 PM »
both my 74 barracuda and 73 dart have factory 2.76s
Alaskan_TA
Re: 355 RATIO
« Reply #10 on: April 17, 2009 - 08:21:17 PM »
Standard & optional axle ratios for 1972 Challengers in the blue chart at this link;
http://www.hamtramck-historical.com/images/dealerships/DealershipDataBook/1972/72_Challenger0019.jpg
