I can't stand mine. Worst mod I have ever made. I'd love to sit here typing glorious things about it (because I have one in my car) but fact of the matter is, I can't, it's THAT bad. I have the "Autoshift sequencer" unit, not the stock manual unit. They're inconsistent, sloppy, jolty and just altogether a waste of cash. All I can say is don't fall for their gimmick "6-Speed Auto!!!!!!!" hype and BS like I unfortunately did. They make it out like you're going to have a 6-Speed short ratio drag racing sounding box LOL.....far from it, my stock shifter with 3 normal TF727 gears hits better 0-60mph times,
easily. I can hit it properly and shift it as good as the next guy with GVs but you can only do so much, especially with a delay from the solenoid. As far as install, that was the easiest part, took 2 solid days to do it properly and allow room in the trans tunnel. The electronics is were my problems are.
They made the Autoshift unit as the stock unit is very messy, check out GVs own video for proof (the Nova ride). Every time you kick out it's like a hunting/delayed sound when the OD kicks out (due to the solenoid delay). Even Rick (manager who I have talked to many times) admits that it is delayed and jolty and that is the reason they are making/made? the Autoshift unit to clean up the OD out, shifts. Just, they sold mine without doing their R&D which we had to end up doing just to get the bulky POS to work. Even now it's always coming out of OD for it's own reason, the electronic module (4th one we've had to use) has a mind of it's own. All I use it for is an OD, the split gears is a waste of time and again, a gimmick. If I could do it again, I'd get an A518 (built) or a manual. Worst mod ever.........
