Author Topic: 70 e body jack location  (Read 1740 times)
« on: April 15, 2009 - 06:14:19 PM »
All the pictures seem to be gone on how to install the jack in a 70 trunk.  Anyone got any pictures for 1970?
Offline JH27N0B
Re: 70 e body jack location
« Reply #1 on: April 15, 2009 - 07:02:06 PM »
Here are a couple.
« Reply #2 on: April 15, 2009 - 07:31:32 PM »
Thanks, that is the way I installed it. Except for the jack hook, where does it go?
Offline JH27N0B
« Reply #3 on: April 15, 2009 - 08:00:41 PM »
On my convertible it goes under the rear of the space saver spare tire.
I think there may be some differences in hook location depending on if you have a space saver or full size spare, convertible or hardtop, and maybe even later production vs. early production.
Hopefully someone can chime in here with all the details of hook location.  I know under the rear of the space saver is correct for my 'vert and for my April built T/A that also has a space saver spare.
« Reply #4 on: April 15, 2009 - 08:03:10 PM »
My hook has a little hole on it, so I put the spring through that hole and the hook stays on the jack ok. Mine was built sep 9 1969
Offline MDMoparDude
« Reply #5 on: April 15, 2009 - 08:05:15 PM »
I dont want to violate any copywriten material, but if you do a google image search for 1970 dodge jack instruction decal you will find it
Offline JH27N0B
« Reply #6 on: April 15, 2009 - 08:05:44 PM »
Here is a picture showing approximately where the hook goes with a space saver.
Offline JH27N0B
« Reply #7 on: April 15, 2009 - 08:11:19 PM »
I just remembered I had a '70 trunk jack sticker sitting in the next room.
It shows the hook where mine is for the convertible and cuda hardtops with space saver.
For Challenger hardtops with space saver it goes on the stud, above the tire and jack base, and below the wing nut. Which is the same as where it goes when you have a full size spare tire.
The decal shows the option of having a full size spare with a convertible, I thought 'verts always got the space saver spare?
Offline 30below
« Reply #8 on: April 24, 2009 - 09:34:41 AM »
Are the two brackets that the jack sit on at the wheelwell and near the tailpanel the same,one facing up and the other down?And is this the same setup on a 73 Cuda?
Offline 30below
« Reply #9 on: April 25, 2009 - 08:49:55 AM »
Bump
Offline farmertan
« Reply #10 on: April 25, 2009 - 11:42:03 AM »
Hey 30below, that pic of his brackets is the same as my 73 just the jacks are different.
73 340 4sp 2nd owner since 85    brett
Offline 30below
« Reply #11 on: April 26, 2009 - 08:39:57 AM »
Thanks very much.
