Author Topic: 340 advice  (Read 3119 times)
Offline 300
  • 69 chevelle,67chevelle , 70 barracuda
340 advice
« on: April 16, 2009 - 04:53:37 PM »
Hi. I,m not much of a engine guy But what is this combo.  69 340,running, 30,000 miles on it,475hp,with Barry Grant six shooter, three deuce carbs and air filter, 10.5.1 comp,93octane pump gas, complete withMSD 6al, headers,mounts,runs 90psi oil press,mounts included,HP 904 trans,3500 stall,trans cooler,lines,rad shroud,electric fan Etc, I,ve got a 70 cuda i,m doing and looking for a engine,  but it will be a 4 gear.Saw this add in a local paper for $4000.00 CDN obo Any thoughts Thanks
Re: 340 advice
« Reply #1 on: April 16, 2009 - 08:46:22 PM »
What stands out to me is that 904 tranny doesn't belong. The torque converter would suggest tall gears in the rear, but this is all unimportant since you apparently have a 4-speed tranny to hook up to this engine. It sounds like quite an engine, but I honestly don't know if it's worth that much. Probably not.   :2cents:
Offline 71chally416
    • The Streetwalker
Re: 340 advice
« Reply #2 on: April 16, 2009 - 09:47:45 PM »
Many 340's & 360's came stock with 904 trannies (or the variant 999) :clueless:
Re: 340 advice
« Reply #3 on: April 16, 2009 - 10:03:09 PM »
better first gear than a 727 :2thumbs:
Offline bb71challenger
Re: 340 advice
« Reply #4 on: April 16, 2009 - 10:19:13 PM »
Is that true? I have never seen a 340 with anything other than a 727. I dont know about 360's because they made a 2 barrel version didnt they? Sounds odd to me for a high performance engine to come with a 904.   :clueless:
*Brett*
Offline 71chally416
    • The Streetwalker
Re: 340 advice
« Reply #5 on: April 16, 2009 - 10:37:29 PM »
Yep. And many Jeeps as well. My sis had one in here '89 Cherokee sport. Over 200K and never a bit of trouble.
Offline 72bluNblu
Re: 340 advice
« Reply #6 on: April 16, 2009 - 11:41:45 PM »
$4k is pretty steep for an engine with 30,000 miles on it. No doubt it cost more than that to build, but a lot can change in 30k miles. Does have some fairly expensive add-ons, but don't forget they're all well used.
Offline HemiOrange70
Re: 340 advice
« Reply #7 on: April 16, 2009 - 11:54:57 PM »
I am in  :canada: and am getting my 340 done for 3k with heads, mostly stock. 10.5 is a bit high for pump gas. THe 6 shooter is worth a few bucks (1500) alone. You are paying for a trans you won't use but not a bad deal.
Offline 71chally416
    • The Streetwalker
Re: 340 advice
« Reply #8 on: April 16, 2009 - 11:58:51 PM »
I'm running 11.69 compression with pump gas.
moparniac
Re: 340 advice
« Reply #9 on: April 17, 2009 - 12:26:39 AM »
what octane and how much duration at 50   :lol2:
Offline 71chally416
    • The Streetwalker
Re: 340 advice
« Reply #10 on: April 17, 2009 - 01:22:06 AM »
Sunoco Ultra gas is all I've used. Don't know the duration off hand. It's the old .528 Mopar solid grind with 1.7 rockers. :dunno:
Offline 300
Re: 340 advice
« Reply #11 on: April 17, 2009 - 05:23:54 AM »
I,ll offer 3k he might take it, it,s been in the paper a few times, if not i,ll  build the one i got, forgot to mention i do have a 70 block and some parts around.
Offline lemming303
  • San Antonio, TX
Re: 340 advice
« Reply #12 on: April 17, 2009 - 11:24:43 AM »
Aluminum heads?
Kevin
73 Challenger Rallye - first project
Offline matt63
Re: 340 advice
« Reply #13 on: April 17, 2009 - 11:43:46 AM »
I doubt a 475hp small block would have much left after 30k.  There is no info on what parts he has to make the hp either.  I would question that.
Matt in Edmonton
'68 Valiant
Offline 71chally416
    • The Streetwalker
Re: 340 advice
« Reply #14 on: April 17, 2009 - 12:02:30 PM »
Aluminum heads?
Commando big ports.   :2thumbs:
