Author Topic: Key stuck in ignition switch upside down...cant get it out  (Read 16568 times)
Offline elevenssc
« on: April 18, 2009 - 08:14:53 PM »
Any suggestions on how to get the "upside down" key out of the switch"?  It is about 3/4 the way in.  I'm thinking the switch assembly is coming out of the steering column...but then what??? :banghead:
(always looking for an opportunity to learn more :stomp:)
Offline hemiken
Re: Key stuck in ignition switch upside down...cant get it out
« Reply #1 on: April 18, 2009 - 08:27:05 PM »
If the housing of the column is not twisted inline the key will not come out, you have to straighten the housing to its original position for it to release.  Try that and let us know if it worked :2thumbs:
Offline elevenssc
« Reply #2 on: April 18, 2009 - 08:57:46 PM »
Nope...
It's stuck in there pretty solid regardless of where the housing is at... :swear:
Offline hemiken
« Reply #3 on: April 18, 2009 - 09:03:42 PM »
Is the column still in its original mounting position bolted to the floor/firewall ?
Offline elevenssc
« Reply #4 on: April 18, 2009 - 09:13:28 PM »
Yes, Original column, original installation
Offline hemiken
« Reply #5 on: April 18, 2009 - 09:15:49 PM »
Does the key push back in ?  try spray some lubricant in the key hole. :2thumbs:
Offline elevenssc
« Reply #6 on: April 18, 2009 - 09:19:22 PM »
I'll give that a try tomorrow...I'll let you know how it goes
Thanks for the help!!!
Offline hemiken
« Reply #7 on: April 18, 2009 - 09:20:47 PM »
No worries, sometime if the housing where the key goes in is not quit lined up right you can be stuck trying to pull the key out, or it could just be frozen from age and dirt.  Goodluck :2thumbs:
« Reply #8 on: April 19, 2009 - 01:32:04 AM »
this is one of the flaws of the Mopar ign , when the key is inserted upside down the buzzer lever locks into the key , you have to slide a thin piece of spring steel either beside the key or under it to depress the buzzer lever & release the key , I have tool to do this , I am not sure what you will be able to make work
Offline willard
    • 1970 Challenger R/T
« Reply #9 on: April 19, 2009 - 04:54:39 AM »
I had the same problem, an idiot in the port tried to put the key upside down into ignition and it was locked. I sprayed it with wd40 and then inserted a straightened paper clip and after a couple of tries it worked.
1970 383 R/T SE
Offline bb71challenger
« Reply #10 on: April 19, 2009 - 05:16:03 AM »
Wow, guess I have better luck than I thought. In all my mopar years I have never had that happen. Sounds like it sucks though and I hope it comes out easily for you.
*Brett*
Offline elevenssc
« Reply #11 on: April 19, 2009 - 08:45:31 PM »
Tried the WD40 thing and no-go...The key is stuck pretty good.
The buzzer lever makes sense.  I'm guessing that the lever rides on the bottom of the correctly installed key, which is flat.  Now that I've installed the key "teeth down", the lever is engaging the teeth, locking the key in place preventing removal.
I'll give the straightened paperclip a shot.  I'll let you know how things go.
On a separate note...I really appreciate the knowledge "on tap" at this site, and the members willing to share that knowledge.  I am constantly amazed and inspired by the friendly interactions and never ending knowledge.  Thanks  :2thumbs:
Offline elevenssc
« Reply #12 on: April 19, 2009 - 09:36:42 PM »
HA-LA-LU-YIA!!!!!!!  The paper clip trick worked!!!!!   :cooldancing:
Thanks Willard and Chryco Psycho for the paper clip info!! :2thumbs:
For future reference, use the small paperclips.  The big ones were too big and didn't fit in the switch next to the key.
What a relief... :woo:  I had visions of spending time and money I dont have tearing out the steering column and replacing the tumbler and key.  ( I really dont like changing perfectly good parts when I dont have to...)
Thanks a bunch!!!
« Reply #13 on: April 19, 2009 - 09:37:32 PM »
worst case you may have to pull the top of the column apart to get to the buzzer lever & you can easily move it out of the way from inside the column to release the key . if you just pull hard on it you will break the key in the lock & still have the saem problem only worse so do not do that
 Glad to help out
« Reply #14 on: April 19, 2009 - 09:38:05 PM »
 :2thumbs:
 nevermind
