Mystery Relay thing
Author Topic: Mystery Relay thing  (Read 1378 times)
Offline 73EStroker
Mystery Relay thing
« on: April 19, 2009 - 10:58:21 AM »
My 73 has a 2 pin relay or buzzer with the following part # 3588492 on it. Can anybody id it for me please. The car is not the highest of option listed so maybe could be a headlight warning or similar. It resides over beside the glovebox according to the harness plug location.
Barry (Salmon Arm)
Re: Mystery Relay thing
« Reply #1 on: April 19, 2009 - 12:05:58 PM »
That is the either the emergency flasher or one for the turn signals.
« Last Edit: April 19, 2009 - 12:22:48 PM by Bullitt- »
« Reply #2 on: April 19, 2009 - 12:22:20 PM »
definatly not , the emergency flasher is mounted to the pedal support & the turn siganl flasher is mounted to the ash tray , this is under the glove box on the right side of the dash
Offline 73EStroker
« Reply #3 on: April 20, 2009 - 11:13:58 PM »
My previous description may be fuzzy. The number I posted is correct, it resides on the far right side of the glovebox and it is a flat rectangular boxxy thing. It is not flasher or blinker as they are round.
Barry (Salmon Arm)
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #4 on: April 21, 2009 - 06:57:31 AM »
my 70 book showes a 2 pin(dark blue & brown wires) time delay in that location and a 3 pin(yellow, red & blue) key in buzzer by the glove box.  :bigshades:
Go Fast & Have Fun...
Offline 73EStroker
« Reply #5 on: April 21, 2009 - 02:16:31 PM »
Thanks. It is the dark blue/brown wires. So this has narrowed it down. Will find out this weekend as after such a long time (2 years plus) I will do some electrical diagnostics and checks (with the starter power wire disconnected) then try her through the key and see what happens. I have gone through this thing from stem to stern and found many attempts by bush mechanics to do wiring. Lots of twisted bare wire and tape joins bound to give trouble so now soldered and heat shrinked.
Barry (Salmon Arm)
« Reply #6 on: April 21, 2009 - 08:34:16 PM »
 :iagree:  time delay , I was checking mine and it was my key buzzer relay. It said the other would be the light delay
