Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Interior and Gauges
(Moderator:
Chryco Psycho
Removing Steering Column
« previous
next »
Print
Pages: [
1
Author
Topic: Removing Steering Column (Read 669 times)
moparniac
Guest
on:
April 19, 2009 - 02:44:49 PM »
I can get it out.. whats the trick....... its unbolted from underneath the dash and looks like some sort of pin going through where th pwoersteering box is..
Logged
MEK-Dangerfield
C-C.com Expert
I don't get NO respect! Member since 1/25/2002
Re: Removing Steering Column
Reply #1 on:
April 19, 2009 - 03:04:58 PM »
You need a punch to get that pin out. It comes out either side of the knuckle. I used an old valve cover bolt and a BFH.
Logged
2016 SXT+. 1 of 524 SXT+'s in Plumb-crazy for 2016.
moparniac
Guest
Reply #2 on:
April 19, 2009 - 05:33:18 PM »
I just pull it out from the plastic retaining clip
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #3 on:
April 19, 2009 - 09:35:32 PM »
Logged
cudadave72
Sr. Member
you motorboatin sob!!!
Reply #4 on:
April 21, 2009 - 06:38:14 PM »
I punched the pin out at the ps pump. What plastic clip are you talking about?
Logged
1972 BS23 H code Cuda, B5 blue, 340 streched to 416 cu in, 727 w/ 8 3/4 rear, 7.23 in the 1/8 mile and 11.38@117mph in the 1/4 on
drag radials
Under restoration! Coming soon... 440cuin R3 Indy SMALL BLOCK monster!!!!
LAA66
Sr. Member
Reply #5 on:
April 21, 2009 - 11:47:50 PM »
It's sometimes easier to take the small roll pin from the leading edge out then pull the column with the guts from the coupler box.
Ay, Mike, a BFH on the knuckle can cause broken bones you know.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Interior and Gauges
(Moderator:
Chryco Psycho
