Author Topic: Upper Control Arms  (Read 949 times)
Offline mmccarty
  • My other ride...
Upper Control Arms
« on: April 19, 2009 - 03:44:51 PM »
It's been a while since I took this apart.  How do I identify the left vs right UCA?  Are the wide arms on each to the front or the back?
There are two short sleeves (spacers?) that are part of the UCAs that came off when the bushings were pressed out.  Where exactly did they go?
Re: Upper Control Arms
« Reply #1 on: April 19, 2009 - 09:43:25 PM »
the sleeves press onto the front bushings
the arms have a flat spot where they hit the frame bumper stop
« Reply #2 on: April 20, 2009 - 07:49:33 AM »
1 1/2 years between posts. Where you been Hiding brother Mc?
Offline mmccarty
  • My other ride...
« Reply #3 on: April 20, 2009 - 08:59:51 PM »
Been to the Middle East and back many times...  I'm getting ready to retire from the Air Force and need to get my '70 Cuda back on wheels to haul from Texas to Wisconsin.
I'm assembling the K-frame on a workbench right now, the chassis is elsewhere.  So the bushing spacers go to the front, spacing the bushing from the control arm.  Which part of the control arm is to the front??  The arm with the dimple for the bumper stop?
« Reply #4 on: April 20, 2009 - 09:32:21 PM »
Yes the two big rubber bushings at the forward mount for the control arms get a metal sleeve inside.
Yes the bumper stop is to the front.
Glad your home. Hope to see more of you here.
Offline mmccarty
  • My other ride...
« Reply #5 on: April 24, 2009 - 09:29:00 PM »
I don't think I was following what you were saying.  I pressed the sleeve onto the bushing and then pressed the bushing into the front arm of the control arm, assuming it was a spacer.  That sure doesn't look right and I don't remember having to pull the sleeves from the bushings during disassembly, the bushings just pressed out.  I can only assume that the sleeve goes on the back of the front bushing after it is pressed into the control arm?  Not sure what it's purpose is on the back, except to maybe provide some extra support.
« Reply #6 on: April 26, 2009 - 12:44:38 AM »
true , it is not a spacer , the bushing goes in first then the ring is pressed on behind onto the bushing , I have no idea why they are there , some cars had them other don`t , I caan only assume it addsuprt to prevent the arm bending while doing Dukes of Hazzard jumps LOL
Offline purple1
  • Worlds first e-body trailer. Member since 3/10/05
« Reply #7 on: April 26, 2009 - 08:14:23 AM »
I could be wrong about this, but I remember reading some place that the extra ring on some upper control arm bushings was because when the bushings were installed the press fit was not tight enough. The rings were installed on the bushings that did not press in at spec. Thats why they are only found on some of the bushings.
Dave :wave:
Worlds first e-body trailer.    Severna Park, Maryland
