Author Topic: How do rear brakes auto adjust?  (Read 4646 times)
Offline Katfish
  • 70 Challenger
« on: April 19, 2009 - 08:16:24 PM »
What's the mechanism that causes the rear brakes to auto adjust.  I see the star wheel with the spring.
I seem to remember my dad going in reverse and slamming on the brakes.  Is this what I need to do?
Thx
Re: How do rear brakes auto adjust?
« Reply #1 on: April 19, 2009 - 08:26:56 PM »
Yes braking in reverse, slamming not necessary, you might make sure the self adjuster is operating if your having issues.
« Reply #2 on: April 19, 2009 - 09:42:08 PM »
there is a cable & a small lever on the rear shoe , as you hit the brakes going backwards this will pull the lever up with the cable & ratchet the gear on the adjuster , if you are missing the cable & lever they wil not adjust
Offline Katfish
  • 70 Challenger
« Reply #3 on: April 19, 2009 - 09:46:46 PM »
Thx for the replies.  Does the e-brake cable need to be connected for this to work?  I do have the cable and rachet gear and lever in place.  But the e-brake assembly is not in place.
Thx
« Reply #4 on: April 19, 2009 - 09:53:39 PM »
it will work without the park brake connected
Offline Katfish
  • 70 Challenger
« Reply #5 on: April 19, 2009 - 10:17:46 PM »
Thx for the info,
I guess I just need to go out and hit the brakes a bunch in reverse now.   :burnout:
« Reply #6 on: April 19, 2009 - 10:19:53 PM »
you can pull the rubber plug & adjust it with a screwdriver
Offline DAYLEY/CHALLENGER
« Reply #7 on: April 19, 2009 - 10:51:04 PM »
Just did my rear brakes yesterday........
Dave or David
« Reply #8 on: April 20, 2009 - 07:35:48 AM »
When I replaced my rear brakes the adjusting lever did not want to engage the star wheel adjuster, found that if with pliers you pull straight down on the lever it "cocks" & when released engages the star wheel.
Offline farmertan
« Reply #9 on: April 20, 2009 - 11:30:17 AM »
Also remember to use lots of never/seize on the star adjuster threads.
73 340 4sp 2nd owner since 85    brett
Offline shadango
« Reply #10 on: April 20, 2009 - 01:22:05 PM »
Is that green return spring in the right hole on theright side?  Seems like it should go to the hole above it...?
« Reply #11 on: April 20, 2009 - 08:30:31 PM »
If I got it in the wrong hole..........please yell.............. :bigsmile: :bigsmile:
Seriously............let me know...............thanks,  :faint:
Dave or David
« Reply #12 on: April 20, 2009 - 09:36:59 PM »
Hard to see but this diagram puts them in the small holes above the large holes.
   Rule of thumb, If it went on easy it must be wrong.  :rofl:
« Last Edit: April 20, 2009 - 09:41:17 PM by Bullitt- »
Offline Katfish
  • 70 Challenger
« Reply #13 on: April 20, 2009 - 10:14:06 PM »
Here's a pic when I had mine apart.  Now I'm not sure where it should go?
« Last Edit: April 20, 2009 - 10:17:30 PM by Katfish »
Offline Purple73Cuda
« Reply #14 on: April 21, 2009 - 07:52:30 AM »
It looks to me like the spring is in the wrong hole. It also looks like the spring is hitting the star wheel because it is in the wrong hole. That could prevent the automatic adjuster from working.
John
'73 Cuda 340
'70 RR 440+6
'66 Charger 383
