Author Topic: Pistol Grip rattle  (Read 1093 times)
Offline 72fish
  • 1972 Plymouth 'Cuda
    • Blue Cuda Studios
Pistol Grip rattle
« on: April 20, 2009 - 09:04:46 AM »
Hey Guys,
Any quick tips on how to eliminate (or reduce!) pistol grip shifter rattle?  The shifter is functioning fine and everything that needs to be tight, seems to be tight. :clueless:
Any suggestions are much appreciated.
Thanks!
Rotisserie Resto - Numbers Matching 'I' Code 340 'Cuda - 4 Spd. -B5 'True Blue'
Blue Cuda Studios, Hi-Res Custom and *Affordable* Show Boards, Prints & Designs
http://www.BlueCudaStudios.com
Offline farmertan
Re: Pistol Grip rattle
« Reply #1 on: April 20, 2009 - 10:09:05 AM »
Back in 86 I put a shim kit in mine,that took the slop out and stopped the rattles.Fairly easy to do but you have to pull the shifter and try different thickness shims.
73 340 4sp 2nd owner since 85    brett
Offline 72fish
    • Blue Cuda Studios
« Reply #2 on: April 20, 2009 - 10:18:48 AM »
Thanks, Brett!  I'll give it a try -maybe Yr1 sells a kit..
Offline farmertan
« Reply #3 on: April 20, 2009 - 10:42:57 AM »
hmmm i just did a quick search, brewers, y.o. , mopar restoration catalog, no ones showing a shim kit, I dont remember where we got ours back then,maybe they want you to send it in and they will do it.Keep looking they have to be out there somewhere.
Offline heminut
« Reply #4 on: April 20, 2009 - 06:43:12 PM »
Another thing that causes rattling problems is the top cap (the part that has the shift pattern on it). A little piece of weatherstrip foam under the grips will usually cure that problem.
1970 5.7 Hemi Cuda
Offline 72fish
    • Blue Cuda Studios
« Reply #5 on: April 20, 2009 - 09:23:52 PM »
Thanks Heminut!  I will definitely give that a try.
Offline pink panther
« Reply #6 on: April 23, 2009 - 02:49:18 PM »
 :iagree: I put a little bead of silicone around mine
