Author Topic: Heater Control Panel Lamp - Part II  (Read 530 times)
Offline Geezer
« on: April 20, 2009 - 06:24:05 PM »
Hi Guys, (me again)
I have mounted the lamp assembly and it does not look
correct. There is only one mounting hole location for the
bracket. Shouldn't the lamp assembly be up in that
somewhat rectangular hole so it will shine down on the
heater controls? What am I missing?
Old Geezer
70 Hemi Challenger Vert. (Clone) under construction.
Offline R/TSE
Re: Heater Control Panel Lamp - Part II
« Reply #1 on: April 20, 2009 - 09:22:14 PM »
I beleive you have the little bracket flipped around.
Alaskan_TA
« Reply #2 on: April 21, 2009 - 12:12:44 AM »
You did not state your model year or application?
That said, these are from a 1970 rallye cluster;
Offline Geezer
« Reply #3 on: April 25, 2009 - 01:44:14 AM »
Thanks TA,
That's just the picture I needed. I found the other mounting hole under the switch in that corner of the switch assembly. Now it looks like your picture. The assembly is going in a '70 Challenger. So that worked out great.
Old Geezer
Offline Slotts
« Reply #4 on: April 25, 2009 - 11:50:12 AM »
It looks like what tripped you up a bit is that someone installed the metal bracket from a non Rallye switch panel on a Rallye switch panel. You can see that Barry's Rallye metal plate has shorter extensions. No bid deal. They can always be trimmed back.
Glad you got it corrrected.  :thumbsup:
Slotts
