I bet that rear u-joint failed or shot a cap off then everything went out of balance and the driveshaft then went crazy spinning so violently that it shook the tail shaft, cracking it. I bet that was scary. I broke a tailshaft housing once because I had a 440 with 6-pack rods with the wrong balancer. The engine vibrated bad at high rpms. I was out cruising and jumped on it hard. The tailshaft cracked all the way around at the rear bearing.
When doing my race car burnouts, My tires were always spinning very fast out of the water, Then I would hit the brakes, while letting off the throttle, grabbing sticky race track. That's kind of like being on ice hitting dry pavement.
KSHE car show is May 3rd. Lots of Dyno tests going on with spectators all around watching at eye level. Kind of makes me want to stand a little farther away now. Going Terry?
Rob
