Hood Pins
Author Topic: Hood Pins  (Read 3662 times)
Offline Katfish
  • 70 Challenger
Re: Hood Pins
« Reply #15 on: February 11, 2011 - 06:52:33 AM »
Holes should already be in the fenders.  Just bolt the pin in the fender, then mark where it hits the hood to drill the holes in the hood.
The hood should have an opening in the metal that gives you a general idea you're in the right area.
Offline RB2929
Re: Hood Pins
« Reply #16 on: February 11, 2011 - 07:50:52 AM »
I left the interior hood release system  in place hoping to avoid unwanted enthusiasts from opening the hood by merely popping the hood pins.
Dutch, how’d the hood pins work out on the trunk lid? Does it increase HP and down force?  :cheers:
Offline challenger_73
Re: Hood Pins
« Reply #17 on: February 11, 2011 - 08:09:03 AM »
The car is far away from me. About 45 minutes. Does anyone have pictures of where they mount on the fenders? Also, how big should the holes be? Thanks guys! Your help is always appreciated.
Offline 360FISH
  • BS23H3B567746
Re: Hood Pins
« Reply #18 on: February 12, 2011 - 12:56:38 AM »
I'm about to do the same to my 73 'Cuda...  I have to add a mounting bracket to mine, but then I'm going to drill a pilot hole to ensure I'm not off the mark.  Then widen the hole to the same size as the hole in the upper metal plate (maybe a tiny bit bigger to be hidden by the plate).    I figure you don't want the hole smaller as it will not be covered up by the plate and too much bigger may cause other problems.
Be sure your hood is adjusted (aligned) where you want it though... Mine has a lot of play and if I'm not careful I could put the hole in a bad spot.
Alan
« Last Edit: February 12, 2011 - 02:33:40 AM by 360FISH »
1973 ‘Cuda   Semi-Pro Touring
360 SB - 518/OD auto tranny - FAST EZ EFI - Edelbrock Fuel sump - HHR fan
Hella H4 headlights on relays - 97 Dodge Avenger seats - Chin spoiler - Bumpers pulled in to ’72 offset
Build: http://www.cuda-challenger.com/cc/index.php?topic=74674.0
Re: Hood Pins
« Reply #19 on: February 15, 2011 - 01:02:22 PM »
One last question... Does anyone know the approximate diameter of the hole that need to be drilled?
challenger_73
