Author Topic: removing graphics  (Read 1180 times)
Offline plumcrazy704406
removing graphics
« on: April 26, 2009 - 07:52:31 AM »
back awhile ago a member said they use oven cleaner to remove the graphics on their race car. i can't find the post, but does anyone know exactly how to use the oven cleaner for this? spray it on, walk away, come back in 30minutes, or do I have to put the car in the oven and preheat it?
seriously members, anyone done this before?
thx
This thought may not be politically correct, but is an opinion offered. It may be correct? or it may be wrong? It is not designed to appease those needing shelter from the real world.
Offline PlumCrazyRTSE
Re: removing graphics
« Reply #1 on: April 26, 2009 - 08:32:41 AM »
I'm not sure about the best way to remove graphics but I wouldn't suggest using oven cleaner.  Easy-Off contains sodium hydroxide or LYE and it will remove your paint as well as the graphics.  I've used Easy-Off to remove dye or paint from plastic interior parts before and it works great for that because it doesn't damage the plastic yet it does a really good job of removing paint.
1970 Challenger R/T SE, 440 Six Pack, Super Track Pak, FC7 Plum Crazy Purple
1970 Challenger R/T SE, 440 Six Pack, Super Track Pak, FE5 Bright Red
« Reply #2 on: April 26, 2009 - 08:35:18 AM »
Unless you plan to repaint the car, I wouldn't touch easy-off. I would try a blow dryer.   :dunno:
Offline 73dce
« Reply #3 on: April 26, 2009 - 10:01:35 AM »
 :iagree:  Heat it up and it comes right off. :thumbsup:
« Reply #4 on: April 26, 2009 - 11:37:54 AM »
I have painted and goldleaf graphics. not so sure the heat would work.
« Reply #5 on: April 26, 2009 - 12:07:01 PM »
I used Easyoff many years ago to remove hand painted signs from a couple of late '70s GM vans.  There was some streaks to polish out where the cleaner ran & kind of dried.  These being well cured factory paint I would hesitate to use on a newer paint job.  More recently I used it to help clean some painted aluminum wheels prior to repaint, did not put a dent in that paint.
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #6 on: April 26, 2009 - 01:24:49 PM »
You're going to take off all your graphics on the Challenger?  :o  :(
« Reply #7 on: April 26, 2009 - 06:35:24 PM »
At the mindset of removing them if I can keep the paint, without having to repaint.
« Reply #8 on: July 12, 2009 - 08:13:34 PM »
well finally decided to try to remove the graphics from the car using easyoff. sorry, it ain't so easy! tried a small spot and won't release. any other ideas?
thx
Offline B5barracuda
« Reply #9 on: July 12, 2009 - 10:31:52 PM »
FWIW,i used pb blaster and my fingernails to get the side moulding off of my barracuda,and it worked out fine(some sore fingers afterwards)but the glue came off.decals however are a different thing,the blaster didnt hurt the paint though,maybe use a little on one spot and see if it helps.  :2cents:
2010 CHALLENGER S/E DEEP WATER BLUE
1970 CORONET 440 FOUR SPEED 30K ORIG MILES
1969 SUPERBEE 383 AUTO 99 PAINT CODE
1996 INDY RAM PACE TRUCK
Offline BIGSHCLUNK
« Reply #10 on: July 12, 2009 - 11:15:42 PM »
I've used the oven cleaner to get lettering off trucks, but dont do it to your car. I would think my microwave machine at the shop would work perfect for you... unfortunately I have no pic. It works great for mouldings and bonded windows. I can get a pic tomorrow if you like. I've never seen one of these anywhere but shops, have no idea if you could even rent one.  :dunno:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
