Author Topic: disk brake conversion  (Read 719 times)
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« on: April 27, 2009 - 11:13:15 AM »
I did a quick search and couldn't find the answer I was looking for. Will the 73 a-body disk brakes with the large bolt pattern bolt onto a 68 barracuda? (complete swap spindles and all)
1996 Dodge Viper GTS Coupe
Re: disk brake conversion
« Reply #1 on: April 27, 2009 - 11:51:46 AM »
I am not sure about the ball joint size being the same , if it lists the same ball joints upper & lower for that yaer I see no problem
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #2 on: April 27, 2009 - 12:12:54 PM »
 :iagree: I think you need the upper control arms for larger ball joint
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline 72hemi
« Reply #3 on: April 27, 2009 - 12:31:43 PM »
Thanks, I looked and the ball joint numbers are different. What about the lowers and the tie rod ends?
« Reply #4 on: April 27, 2009 - 01:37:23 PM »
tie rods should be the saem , is the lower ball joint the same part # , if not I would bet th elater ball joint will bolt up
Offline 72bluNblu
« Reply #5 on: April 27, 2009 - 02:41:49 PM »
You will need the upper control arms, as already pointed out, because of the larger ball joint. I'm not sure what size drums the '68's had, I know that a lot of the 9" drum cars were equipped with smaller lower ball joints as well. If thats the case, you'll also need the later lower ball joints and the bolts to go with them. The geometry was the same, so the lowers will just bolt up to the tie rods, but the later model one's had larger ball joints and used 1/2" instead of 7/16" bolts.
Offline 72hemi
« Reply #6 on: April 27, 2009 - 02:48:21 PM »
Great, thanks everyone.
