Author Topic: Power Booster Source  (Read 1838 times)
Offline basement
« on: April 27, 2009 - 03:52:53 PM »
Finally had enough, and want to replace the power brake booster/master cylinder combo and would like to know a good source?
Re: Power Booster Source
« Reply #1 on: April 27, 2009 - 07:02:17 PM »
Only sources I know of for boosters are the rebuilt units available from any parts store, new master cylinders about the same. You might consider having Booster Dewey rebuild & refinish yours for just a little more than the poorly finished parts store pieces.
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #2 on: April 27, 2009 - 07:08:25 PM »
I've had good luck getting them from Kragens. They are raybestos parts. Here is booster deweys website if you want to go that route.
http://boosterdeweyexchange.com/
1996 Dodge Viper GTS Coupe
« Reply #3 on: April 27, 2009 - 07:16:05 PM »
I had Brake booster Dewey re build my Hemi Booster. But if you want to buy one outright and not hassle with the exchange deal, you can go thru Jims Auto Parts. He sells boosters and brake master cylinders.
http://www.jimsautoparts.com/brake.htm
Offline 72hemi
« Reply #4 on: April 27, 2009 - 07:23:32 PM »
Jim's prices are insane.  :22yikes: I never pay more than 150 from kragens for a master/booster combo.
« Reply #5 on: April 27, 2009 - 08:13:38 PM »
Some are factory correct apprearing and some aren't.
Buyer needs to use their own discretion if they want OEM look or not. I wouldn't think any at CSK are factory correct appearing.
Offline cwestra
« Reply #6 on: August 25, 2009 - 04:03:54 PM »
What is the correct factory look for MC and booster for '70 Cuda with disc brakes?
Corey - in Northern Indiana
Alaskan_TA
« Reply #7 on: August 25, 2009 - 06:56:26 PM »
Gloss black for '70.
The booster, master cylinder, bail, lid & check valve were all painted as an assembly.
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« Reply #8 on: August 26, 2009 - 02:28:45 AM »
I bought mine last month from autozone.  I saved about $20 buying the booster and M/C separately versus buying the booster and M/C combo.
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
Offline cwestra
« Reply #9 on: August 26, 2009 - 06:56:52 AM »
Thanks for the pic.  Looks like they sent you the correct MC (small front resevoir, large rear).  Was this from Cardone?
Offline hooD
  • detroit iron
« Reply #10 on: August 27, 2009 - 01:37:06 AM »
Yes it was cardone.  Everything was almost the same.  The new booster has a spacer that goes between it and the master cylinder.  Other than that it was all good.
-Larry
1973 'CUDA 340
original owner
37,117 miles
Offline cwestra
« Reply #11 on: August 27, 2009 - 07:10:07 AM »
Thanks.  The booster/MC combo unit I originally purchased from Napa, which had equal size resevoirs (front & rear), also had the spacer.  I assumed it was associated with the particular MC they sent me.  Apparently not, based on what you received.  Any idea what the purpose of the spacer is?
Offline hooD
  • detroit iron
« Reply #12 on: August 28, 2009 - 01:47:10 AM »
Well this is my guess only....I think its for the rod length that comes out from the booster.  Even though the rod is adjustable, I think the spacer keeps it in the "ball park" without any need for additional adjusting.  Below is a picture of the factory original booster.
-Larry
1973 'CUDA 340
original owner
37,117 miles
