Author Topic: Map Light  (Read 1383 times)
Offline 73EStroker
Map Light
« on: April 29, 2009 - 02:03:51 PM »
Anyone got a wiring diagram of the map light system. I have the harness, the lampholder and the switch but the plugs look incompatible so just need the diagram and I will make it work. Thanks
Barry (Salmon Arm)
Offline 73EStroker
Re: Map Light
« Reply #1 on: May 15, 2009 - 11:37:52 PM »
 :dunno: no one got this schematic???????????????
Barry (Salmon Arm)
Offline LAA66
Re: Map Light
« Reply #2 on: May 15, 2009 - 11:48:01 PM »
 Don't have what your looking for but I think the (yellow) door/dome light wires are part of the circuit.
Offline 73EStroker
Re: Map Light
« Reply #3 on: May 16, 2009 - 06:32:45 PM »
Yes ..... I believe it is part of the door courtesy system as well but even Chryco and I were a little stumped with what I had vs where to plug it all into. Hence the need for the diagram please anybody.
Barry (Salmon Arm)
Offline Katfish
  • 70 Challenger
Re: Map Light
« Reply #4 on: May 16, 2009 - 07:04:28 PM »
You can get the wiring diagram here:
http://www.mymopar.com/index.php?pid=24
http://www.mymopar.com/downloads/1973/73ChallengerB.JPG
But it only needs power and ground.  I connected the + to the accessory in the fuse box, then connected ground through the toggle switch.
« Last Edit: May 16, 2009 - 07:07:36 PM by Katfish »
