Author Topic: how to headlight relay?  (Read 2680 times)
Offline barracuda7199
  • needs a resto but having to much fun right now
« on: May 01, 2009 - 10:09:16 AM »
i want to put my headlights on relays 71 cuda. anybody done it on a 71? where to get the relays? what wires to cut?
Brandon
71 Barracuda 440 727
(O O {]{]{]|[}[}[} O O)
Re: how to headlight relay?
« Reply #1 on: May 01, 2009 - 10:26:01 AM »
Someone posted this in the past and I saved it. I hope it helps. You should be able to get generic relays locally. I have even seen them at Walmart.
« Reply #2 on: May 01, 2009 - 10:30:07 AM »
Look in Goody's How To section....
http://www.goodysgotacuda.com/
« Reply #3 on: May 01, 2009 - 10:34:37 AM »
sweet! how would it be done on a 71 with multiple headlights? would i need 4 relays or still just 2?
Brandon
« Reply #4 on: May 01, 2009 - 10:37:40 AM »
You need two relays. One for the low beams, and one for the high. The hi beam wires run to all the bulbs.
Offline the_engineers
« Reply #5 on: May 01, 2009 - 11:16:39 AM »
If you have fog lights and want them to turn off when you turn on the brights, you'll need three relays.  I have done this on a '71 and can dig out the diagrams.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
« Reply #6 on: May 01, 2009 - 11:32:52 AM »
i would appreciatte it! driving this thing at night is scary! i had roadlamps but sold them. i am going to bypass the ammeter as well going to cut and splice the wires on the engine side of the bulkhead. to try and get more juice to the battery and eliminate a fire hazard as well. only thing extra i run is a msd and a cd player no amp or anything.
Brandon
« Reply #7 on: May 02, 2009 - 10:14:27 PM »
Brandon
Offline ShelbyDogg
« Reply #8 on: May 02, 2009 - 11:05:40 PM »
http://cgi.ebay.com/OEM-HD-DUAL-Relay-Harness-2-HD-40-Amp-Relays_W0QQitemZ350172762688QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item5187ec5240&_trksid=p4634.c0.m14.l1262&_trkparms=|301%3A1|293%3A1|294%3A30
would these work even though they are five wire? whats the fifth wire for?
The 5th wire on automotive relays is for the normally closed (NC) contact. Using this Ebay setup would be a good price $7.99 for 2 relays and their sockets. I would order more that one because a pair of relays have unlimited uses for alarm systems and controlling add-ons.
« Last Edit: May 02, 2009 - 11:07:17 PM by ShelbyDogg »
« Reply #9 on: May 03, 2009 - 07:23:35 AM »
sweet! i will get there yet. sending my headlight switch to slotts monday soon as it returns the relays will be installed as well.
Brandon
Offline 422STROKER
  • Member Since 6/3/06
« Reply #10 on: May 03, 2009 - 08:36:14 AM »
You don't need to cut any wires to do the upgrade.  Use the existing headlight wiring for the "trigger" wires.  You are still taking the substantial load off of the headlight switch. :2cents:
The ammeter bypass can be done many ways.  I ended up cleaning all the original connections and adding a piece of #8 from the Alt to the Starter relay in parallel to the existing wiring(#10) this leaves all the factory stuff intact but allows an easier path to the battery for the power to flow.  The ammeter doesn't work properly anymore, but I added a Voltmeter to keep an eye on things.
Tom
Tom
« Reply #11 on: May 03, 2009 - 09:19:12 AM »
i am going to use the existing headlight wires but i will have to cut wires and splice the relay into the factory headlight wires the only new wires i will need is a 12v feed wire and a ground. i can't wait! going to go junkyard hunting for a denso alternator like goody has simply for the boost in amps at an idle. then i will run a new wire straight to the starter relay and cut the ammeter wire completely out of the picture.
« Last Edit: May 03, 2009 - 09:21:41 AM by barracuda7199 »
Brandon
« Reply #12 on: May 04, 2009 - 11:19:51 AM »
Previous discussion on this was in this thread...
May be able to add the two together to get what you need.
http://www.cuda-challenger.com/cc/index.php?topic=49875.15
Brooks
1971 'Cuda 360
