Author Topic: super vague 4 speed man question  (Read 800 times)
Offline BB73Challenger
« on: May 01, 2009 - 04:08:13 PM »
Hi all,
I know this is going to require a lot more of looking into but....
I obviously have a standard A833 4 speed, and lately has been giving me a lot of trouble getting into 1st gear.
Shifts into the other gears nicely when past 1st.
Could I be having a problem with the linkage rods themselves??
I was hoping that maybe it could be addressed or even just begin looking at possibilities before dropping the trans for any reason.
I know that with trannys it's hard to say with any 1 problem that it has any 1 magic fix.
I don't have a lot of experience with these, so if anyone could even make a suggestion that would be appreciated too!
Thanks in advance,
Jeff
Jeff from Cleveland, Ohio
Offline pink panther
Re: super vague 4 speed man question
« Reply #1 on: May 01, 2009 - 04:13:32 PM »
have you tried adjusting the linkage?
Offline Changin Gears
« Reply #2 on: May 01, 2009 - 05:41:35 PM »
It could also be the nut that holds the 1-2 shift lever on the trans came loose.  Another comon problem is the shifter mounting plate itself beign loose.  I'll bet it's shifter/linkage, not internal tranny.
« Reply #3 on: May 01, 2009 - 06:08:21 PM »
I have not tried to adjust the linkage, honestly, I have not had to before and may not know how exactly.
Also, I was hoping to try some "outer" items, as this has not been such a problem before.
I will be getting her up and check these things, as well as get someone to run her through the gears to see what I can see.
Thanks for the ideas, I'm going to try and get it going!   :wave:
« Reply #4 on: May 02, 2009 - 01:00:59 AM »
Lubrication makes a big difference as well
Offline ShelbyDogg
« Reply #5 on: May 02, 2009 - 10:40:49 PM »
Is it hard to get into Reverse too?  I'm guessing that you clutch linkage is a little loose and you aren't releasing all the way.
