My tranny is the 904 with a cheetah manual valve body. About 5 years old, changed the fluid 2007 but it gets store during the winter.
Well when cold-semi warm I felt it sipping from a dead stop while in 3rd gear. Went back and check the fluid level, was fine. So I adjusted the kickdown band. Felt fine afterward in 3rd but then in 1st gear it slip again but I floored it and it ran fine and was OK for 20 mins in all type of driving. Had dinner, ran out and I felt it slip in 2nd from a dead stop again, seem to shake this time. Once again when warmed up was great.
I pulled the pan off, not too bad inside, some grit-the size of a US half dollar coin. Filter had about the same...but then when cleaning the pan I found a thin washer with a slot, hope you can tell by the pictures...all valve body bolts seem tight, just a got a slight turn on a few..very slight.
