Author Topic: Engine advise needed  (Read 735 times)
Offline pink70
« on: May 01, 2009 - 11:51:03 PM »
Well, I have decided to stick with the small block and have two options, stroke the orginal 318  or build up a 340.  How big can you stroke a 318 to? We are going to use aftermarket heads and a six pack. What cam and heads do you suggest we use for either option?
Any advise would be appreciated.
Cheers
Toni
Toni
Re: Engine advise needed
« Reply #1 on: May 02, 2009 - 01:08:11 AM »
well if you are going to stroke a 318 why not stroke the 360 up to 412 ci , you can go bigger but you need an aftermarket block to do it so it would depend on your budget
 I would use ported 308 casting producion heads or step up to the W2 Mopar heads but W2 has no intake for the 6 pack , IMO the eddy heads are not better than the Production 308 castings & I do not know of another good small block head . The W2 will make far more power than the Eddys or any production head but they need special headers inatke , rockers & pushrods etc to work
Offline Changin Gears
« Reply #2 on: May 02, 2009 - 06:52:03 AM »
I agree, 360 blocks are quite cheap.
Offline pink70
« Reply #3 on: May 05, 2009 - 12:33:59 AM »
I have taken your guys advise and purchased a 79 360, does anyone know of a good engine builder in the Portland area. Have decided to get this done over there and then ship back to Aus when completed. Engine building in Perth is very expensive.
Toni
« Reply #4 on: May 05, 2009 - 03:33:07 AM »
I have an excellent machinist near me but I have no clue on a good one in the Portland area
Sorry
Offline pink70
« Reply #5 on: May 05, 2009 - 06:24:17 PM »
OK, next question, will a 904 trans go onto a 360?
Toni
« Reply #6 on: May 05, 2009 - 08:22:54 PM »
yes with a balanced converter for the 360
