Misc parts for sale
Author Topic: Misc parts for sale  (Read 2367 times)
Misc parts for sale
« on: May 02, 2009 - 10:40:14 AM »
Check it out, pm or email me, highplains@comcast.net Parts are in Colorado, 80907. You pay shipping in most cases, but we can negotiate that.
$205.00   Hurst Pistol Grip Shifter (1970-74 E-Body, 1971-74B-Body with Console)
$180.00     ARE Viper caliper adapter brackets
$75.00   adj pinion snubber 8 3/4
$65.00   alum shackle bushing
$50.00   Super Bee Emblem — Grille (1969 Super Bee)
$50.00   440 tall throttle bracket
$50.00   383 tall throttle bracket
$50.00   360 tall throttle bracket
$50.00   W2 tall throttle bracket
$50.00   A body  Lwr arm poly pivot
$50.00   RB block tall throttle bracket
$50.00   axle shim set
$45.00   kickdown cable style bracket
$40.00       disc brake spindles
$40.00   T-bar removal tool
$40.00   R/T Nameplate Emblem — Grille (1970-71 E-Body
$30.00   C body washer bottle
$30.00   Hood Pin and Cable Kit
$30.00   “440 6-bbl” Hood Decal
$30.00   Upper ball joint separator
$25.00   t-bar adjuster block/screw
$25.00   J bolt for gas tank straps
$25.00   8.75 pinion thrust washer kit
$24.00   BB chrome dist hold down
$20.00   Lower control arm bracing plate, A, B, E
$20.00   Lower control arm bracing plate, late B
$20.00   66-70 steering wheel assy
$20.00   67 GTX back up lenses
$20.00   big block throttle return set for tall linkage set
$15.00   Standing RR w/ helmet decal
$15.00   Porting Template big block— 2.08/1.74 Valve Size, Cast Iron Head
$10.00   340 main bearing set
$10.00   upper control arm cam bolt assy
$10.00   heater hose bracket 67-68 big block w a/c
$10.00   3/8 tank filter sock
$10.00   Dart grill
$9.00           Street Hemi Orange Engine Paint
$9.00           Red engine enamel
$5.00           74 Plymouth hub caps
$5.00           spare tire hold down wing nut
$5.00           universal ign wire loom
$5.00           thermostatic switch
$5.00           NOS big block throttle return spring
$5.00          OE ignition key blank
$3.00          valve lash decal
$3.00          DC large decal
$1.50       SB exhaust manifold sleeve nuts
$1.00          5/16 corbin clamp
$1.00          3/8 corbin clamp
Additions;
5" Autometer carbon fiber 10k tach   $150
Black Magic electric fan   $125
440 pushrods 9.265"   $90
pinto a arms   $20
15" Magnum trim rings   $40
Road Runner turn signals   $30
B&M unimatic 5" cable   $30
dual point sets   $10
battery box   $10
« Last Edit: September 27, 2009 - 09:58:33 PM by HP2 »
Re: Misc parts for sale
« Reply #1 on: September 02, 2009 - 10:17:54 PM »
tool pictures
Offline swede-cuda
« Reply #2 on: September 13, 2009 - 03:41:01 PM »
hej hp2.have you recieved my email about the stickers and the 11.75 adapters and those porting templates.haaalååå.anderzsweden@hotmail.com
Offline Katfish
  • 70 Challenger
« Reply #3 on: September 13, 2009 - 03:53:16 PM »
PM sent about axle shims.
« Reply #4 on: September 13, 2009 - 07:39:16 PM »
swede-cuda, I haven't received your inquiry about those parts. The 11.75 adapters are sold, but I do have some stickers.
katfish, pm sent.
Offline Rob74dodge
  • 1974 Challenger
« Reply #5 on: September 14, 2009 - 07:34:02 PM »
Interested in the 340 main bearings. Are they full groove or not, in the box?
Building a 68' soon...I hope. Parts at machine shop.
Thanks
Offline kmyles
« Reply #6 on: September 17, 2009 - 04:50:14 PM »
What year is this for??
_________
Kevin
Mopar Lover....Cuda's....Challengers Rule!!!!
- 1951 Dodge - 2 door hardtop (Sold!!)
- 1971 Dodge Challenger
- 2012 Dodge Challenger Yellowjacket
Hard to believe what 20 years will do!!!!
Offline the_engineers
« Reply #7 on: September 17, 2009 - 04:58:38 PM »
I assume this is a pair of Lower control arm bracing plates?  If so, ship 'em.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
« Reply #8 on: September 17, 2009 - 07:55:35 PM »
Thanks
Full groove, new in the box, still in the shrink wrap on the card. They are for a crank that has been cut .020 undersized. On the end flap is Michigan 77 #MS-963-P-20  1922 P 020 I can email you a pic of the box if you like.
Offline farmertan
« Reply #9 on: September 17, 2009 - 08:10:08 PM »
What year dart grill?
73 340 4sp 2nd owner since 85    brett
« Reply #10 on: September 17, 2009 - 10:33:43 PM »
Unsure of the year. It kind of looks like the kickdown spring. They are gray in color. I'll post a picture tomorrow when the upload folder clears.
« Last Edit: September 26, 2009 - 07:36:16 AM by HP2 »
« Reply #11 on: September 17, 2009 - 10:37:21 PM »
Yup. PM sent.
« Reply #12 on: September 17, 2009 - 10:42:43 PM »
75 or 76, black plastic.
Offline Rob74dodge
  • 1974 Challenger
« Reply #13 on: September 26, 2009 - 02:56:11 AM »
On the main bearings, my crank is std. so oh well.
Sorry so long a delay, our comp. was on the fritz and just got it back from the shop today.
Good luck on moving you're parts. :)
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #14 on: September 26, 2009 - 10:09:13 AM »
Hi HP2, just a burning question I've had for the last few weeks and for the sake of the general public:
The hood pin and cable set, what company?  Mopar, with the thick hood plates?  How long are the cables?  I think Challengers are 18", yes?  :clueless:
