Check it out, pm or email me,
highplains@comcast.net Parts are in Colorado, 80907. You pay shipping in most cases, but we can negotiate that.
$205.00 Hurst Pistol Grip Shifter (1970-74 E-Body, 1971-74B-Body with Console)
$180.00 ARE Viper caliper adapter brackets
$75.00 adj pinion snubber 8 3/4
$65.00 alum shackle bushing
$50.00 Super Bee Emblem — Grille (1969 Super Bee)
$50.00 440 tall throttle bracket
$50.00 383 tall throttle bracket
$50.00 360 tall throttle bracket
$50.00 W2 tall throttle bracket
$50.00 A body Lwr arm poly pivot
$50.00 RB block tall throttle bracket
$50.00 axle shim set
$45.00 kickdown cable style bracket
$40.00 disc brake spindles
$40.00 T-bar removal tool
$40.00 R/T Nameplate Emblem — Grille (1970-71 E-Body
$30.00 C body washer bottle
$30.00 Hood Pin and Cable Kit
$30.00 “440 6-bbl” Hood Decal
$30.00 Upper ball joint separator
$25.00 t-bar adjuster block/screw
$25.00 J bolt for gas tank straps
$25.00 8.75 pinion thrust washer kit
$24.00 BB chrome dist hold down
$20.00 Lower control arm bracing plate, A, B, E
$20.00 Lower control arm bracing plate, late B
$20.00 66-70 steering wheel assy
$20.00 67 GTX back up lenses
$20.00 big block throttle return set for tall linkage set
$15.00 Standing RR w/ helmet decal
$15.00 Porting Template big block— 2.08/1.74 Valve Size, Cast Iron Head
$10.00 340 main bearing set
$10.00 upper control arm cam bolt assy
$10.00 heater hose bracket 67-68 big block w a/c
$10.00 3/8 tank filter sock
$10.00 Dart grill
$9.00 Street Hemi Orange Engine Paint
$9.00 Red engine enamel
$5.00 74 Plymouth hub caps
$5.00 spare tire hold down wing nut
$5.00 universal ign wire loom
$5.00 thermostatic switch
$5.00 NOS big block throttle return spring
$5.00 OE ignition key blank
$3.00 valve lash decal
$3.00 DC large decal
$1.50 SB exhaust manifold sleeve nuts
$1.00 5/16 corbin clamp
$1.00 3/8 corbin clamp
Additions;
5" Autometer carbon fiber 10k tach $150
Black Magic electric fan $125
440 pushrods 9.265" $90
pinto a arms $20
15" Magnum trim rings $40
Road Runner turn signals $30
B&M unimatic 5" cable $30
dual point sets $10
battery box $10
