Author Topic: Front sway bar brackets wanted  (Read 2698 times)
« on: May 03, 2009 - 12:46:24 PM »
Looking for the brackets and bolts that bolt onto the K member. OEM.
Alaskan_TA
Re: Front sway bar brackets wanted
« Reply #1 on: May 03, 2009 - 03:19:58 PM »
I have one with bolts if you can locate another single.
Offline 73Chally
« Reply #2 on: May 03, 2009 - 04:03:30 PM »
I just picked up a set from Year One that were identical to my originals.  Paddock has them also for a little cheaper, but if you go to Moparts there is a Year One code that will get you 15% off I believe.
« Reply #3 on: May 03, 2009 - 04:30:26 PM »
Thanks, I'm going to check it out.
Offline Bluemonster71RT
« Reply #4 on: May 03, 2009 - 08:19:32 PM »
I got my bolts from Jims auto parts and the bushing brackets from Y1.  Thankfully I found my k-frame brackets. I havent seen them anywhere.
1971 Challenger RT 383 4spd
« Reply #5 on: May 03, 2009 - 08:23:03 PM »
I looked on YO and didn't see the OEM brackets listed. Nor on Jim's.
Also, I have the oversized ADDCO sway bar.
It should work?
Offline Katfish
  • 70 Challenger
« Reply #7 on: May 03, 2009 - 09:13:28 PM »
Offline 73Chally
« Reply #8 on: May 03, 2009 - 09:14:26 PM »
 :wow: Nice price.  I wish I had seen that last month.
« Reply #9 on: May 03, 2009 - 09:25:26 PM »
I have those.
What I'm looking for are the ones these bolt onto that bolt onto the K member.
Offline Katfish
  • 70 Challenger
« Reply #10 on: May 04, 2009 - 05:58:13 AM »
I have those.
They have those too, but I just bought SS at Home Depot.
http://www.rtspecialties.net/proddetail.asp?prod=1000285
« Reply #11 on: May 04, 2009 - 09:19:28 AM »
Thanks, I do need those also.  :2thumbs:
I was on Moparts last night and I think I might've found the straight brackets.
Offline 1black71rt
« Reply #12 on: May 05, 2009 - 12:30:13 AM »
Hi if you need one more i have one but it has some small rust pits in it. It will still work just not perfict. Just let me know.
Thanks, Joe  :2thumbs:
Joe
1971 triple black challenger r/t
1971 charger se
1997 dodge ram SST
2010 challenger r/t
« Reply #13 on: May 05, 2009 - 12:45:49 AM »
Thanks everyone, I was able to locate them and buy them.
