I'm changing the cam as I think it's the last thing that can heal this engine (idling roughly, good vacuum, good compression, new ignition, set timing but doesnt like idling below 900 rpm (shaking) and having not enough power).
1. does this cam looks like wiped? I dont have a suitable caliper and dont know the cam specs (it only has a cast 1103 number)?
2. do the pushrods (marked MPR321, with both ends identical) have top and bottom end or they can be put in any position?
3. is it normal that it is had to turn the engine (t/c not removed) with plugs and rockers removed? I must apply a considerable force on 10" ratchet to rotate the crankshaft. of course with plugs in I have to overcome the compression building up but without them I did not expect so heavy resistance from torque converter...
