Author Topic: help with starter  (Read 1025 times)
Offline lilian
help with starter
« on: May 05, 2009 - 03:07:17 PM »
5.7L hemi + A833 + TTi swap tubular headers = which starter to choose
looks like my original starter won't do the job. i have read that I may go with a mini starter but which one will work ?
thanks for your help,
Lilian
BS23N0B
Re: help with starter
« Reply #1 on: May 05, 2009 - 08:19:05 PM »
the Hemi starter I have mounts differently to the LA & Magnum engines so I am not sure which aftermarket starter will mount to the Hemi
Offline heminut
« Reply #2 on: May 05, 2009 - 08:25:15 PM »
I used the mini starter that comes on the 5.2 & 5.9 magnum engines on my 5.7 hemi swap in my Cuda. I have a TF727, but your application should be the same if you're using an LA engine bellhousing.
1970 5.7 Hemi Cuda
Offline lilian
« Reply #3 on: May 06, 2009 - 10:32:10 AM »
thanks heminut and chryco
but how do you find which bellhousing I have ?
BS23N0B
« Reply #4 on: May 06, 2009 - 11:38:38 AM »
if you have the 833 a V6 dodge truck starter would be what I would try
Offline heminut
« Reply #5 on: May 06, 2009 - 06:07:10 PM »
It has to be an LA bellhousing or a 5.7/6.1 bellhousing, anything else will not bolt up without an adapter. Since you have an 833 tranny on it I figure you have an LA bellhousing as I don't believe the late hemi bellhousing would accept an 833 tranny.
1970 5.7 Hemi Cuda
Offline lilian
« Reply #6 on: May 11, 2009 - 01:59:15 PM »
engine and trans are out of the cuda I will try to bolt them next week end
thanks
BS23N0B
