Author Topic: Performance Tune 2009 Challenger R/T - help!  (Read 10429 times)
Offline FORDMOPAR70
« on: May 05, 2009 - 08:17:50 PM »
Okay, you have to understand I have driven mostly Mustangs and have modified several of them.  So when I first mashed on the pedal  on this Challenger at 20mph and it responded like a water buffalo stuck in a mud pit , I knew a tune was in order(from a stop it will roast the tires, nicely though).  Compared to the relatively small mustang this vehicle is a tank!  SCT does not have a template yet available for tuning, to my knowledge anyway.  I am a little weary of using a predator  :dunno: since the SCT seens to have better built tunes (mustangs).  I would like to use a C&L intake paired with a SCT tuner.
Has anyone found a good combination for cold air intake kit and tuner for the 2009 5.7?  This challenger is AWESOME, it just needs a little tweaking. :worshippy
Offline 71bigblock
    • Steve's Mopars
Re: Performance Tune 2009 Challenger R/T - help!
« Reply #1 on: May 05, 2009 - 10:12:53 PM »
Guys absolutely rave about the Predator, I guess its the cats meow.  Over on LXforums.com.
Oh and I think that the best intake is the Airhammer, but I dont know if he's still making them.  He made them for the other LX cars, dont know why one wouldnt fit the Challenger.
And the ad at the bottom of the page right now is a superchips ad, lol.
« Last Edit: May 05, 2009 - 10:16:54 PM by 71bigblock »
Offline TorRed R/T
« Reply #2 on: May 06, 2009 - 04:40:49 AM »
You also need to consider adding 180 T-stat, You have a 6Spd or Auto?
72 500cid Challenger
99 Ram
09 Challenger R/T TorRed 6spd
1982 -88 US Marines 2006-??? US Army
Offline Old MrB
« Reply #3 on: May 07, 2009 - 10:40:40 AM »
Interesting stuff guys.  But I'm curious, what temp thermostat is in the engine origonally?  Or did I misinterpret the 180 T-stat?
1970 Barracuda (318)
1973 Duster (360)
1984 F-250 4X4 (7.1l)
1984 MB 200
1988 Mazda 626
1993 Camry
2002 SEAT Alhambra (diesel)
2009 R/T Classic (on order)
Offline TorRed R/T
« Reply #4 on: May 07, 2009 - 01:07:34 PM »
They come factory with 198  because of better fuel economy , the newer Hemis run better cooler so that with retune with Predator .
99 Ram
« Reply #5 on: May 07, 2009 - 01:17:44 PM »
I have to agree , I drove an SRT8 6 spd & was amazed at how underpowered 425 HP is , either the engine I build make a lot more & 425 is boring or the way they are tuned they don`t pull very hard , my friend has a dyno & an SRT8 magnum & said he only got 25 more HP from a cold air box & a chip tune on his
Offline FORDMOPAR70
« Reply #6 on: May 07, 2009 - 11:13:11 PM »
Huh, hadn't thought of the thermostat.  Does it require taking a college course before being able to change it?  On the tranny question, my wife cannot drive a stick.  Unhappy wife = no challenger;  challenger 6 sp = no wife.
Offline TorRed R/T
« Reply #7 on: May 08, 2009 - 03:19:51 AM »
No only the usual 15 -20 minutes  but have to have the Predator (I am unsure if the SCT will do this but probably )to reprogrammer cooling fans to work with the lower T-stat , but this seems to at least make it feel more responsive  :burnout: many say that these 2 are the first Performance tune that they should have done , as far as the Trans well choices , choices ,choices  :pullinghair:
99 Ram
Offline Old MrB
« Reply #8 on: May 08, 2009 - 09:52:21 AM »
So just to be straight  :-\  The Predator is only used to reprogram the car's computer and you only need to do this if mods are made?  The thing doesn't have to stay in the car does it? :popcorn:
1973 Duster (360)
1984 MB 200
1988 Mazda 626
1993 Camry
Offline TorRed R/T
« Reply #9 on: May 08, 2009 - 10:15:24 AM »
Correct it a hand held scanner/programmer plugs into OBDII port saves factory settings (for backup and wty reapair reasons) and the scroll to adjust settings on PCM  when finished disconnect and drive.
99 Ram
Offline FORDMOPAR70
« Reply #10 on: May 09, 2009 - 01:46:20 PM »
Can anyone speak on whether the Predator increases throttle response?  Also, does it seem to help with downshift from 4th to 3rd on acceleration?  :-\
Offline 71bigblock
    • Steve's Mopars
« Reply #11 on: May 09, 2009 - 01:52:10 PM »
I've been wondering about throttle response, too, for the '04 truck hemi I stuck in my project, the throttle response sure takes some getting used to...
Offline TorRed R/T
« Reply #12 on: May 09, 2009 - 10:55:17 PM »
Thats the biggest part of that you will notice.
 The probably best Performance add-ons would be a 180 tstat / Predator tune and CAI :cheers:
99 Ram
Offline FORDMOPAR70
« Reply #13 on: May 10, 2009 - 10:51:53 PM »
180 t-stat, predator u7135 and CAI= a whole different car!  I thought the perfomance tune did wonders for the Mustang, but this is IMPRESSIVE! :jumping:
BTW, I am noticing a rattle at start up which immediately goes away, almost sounds like valve train noise - lack of lubrication.  Anyone else have this issue? 451 miles.  Oil was just changed but engine made this noise when started up on the showroom floor too.
Offline 71bigblock
    • Steve's Mopars
« Reply #14 on: May 10, 2009 - 11:02:22 PM »
My '04 Hemi that I stuck in my pickup kinda sounds the same, I think I know the noise you speak of.  I think its just the nature of the beast.
Great to hear it woke it up some.   :thumbsup:
