Author Topic: Any one use a hydrobreak system?  (Read 1658 times)
Offline Bluemonster71RT
« on: May 06, 2009 - 12:48:08 PM »
The system replaces the booster and makes use of the power steering pump for its power. I guess used for space limitations and or cars with big cams that have little vacume to spare.
  My friend needs something like this as his valve cover hits the booster with the new heads he has. (non Mopar car).  Just wondering if anyone here has used the system on a muscle car? In fact I am cutting a rocker off a Suburban today and it has the factory version of this system on it. So I guess it works well with a stock vehicle.
1971 Challenger RT 383 4spd
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
Re: Any one use a hydrobreak system?
« Reply #1 on: May 06, 2009 - 12:52:05 PM »
Hydraboost systems are becoming more common. Dodge trucks (at least the deisels for sure) have them from the factory. My Dad works for a high end cobra builder and he uses hydraboost systems exclusively on his cars. From what I hear they are definitely the way to go.
1996 Dodge Viper GTS Coupe
Offline HemiDog
  • Do not Assume!
    • Hemi Dog
« Reply #2 on: May 06, 2009 - 03:55:50 PM »
Offline heminut
« Reply #3 on: May 06, 2009 - 06:12:11 PM »
I believe Carlwalski put one in his car. The hydroboost system has been around for a long time and is a proven system. I've seen several writeups in the car mags where they have been used with excellent results.
1970 5.7 Hemi Cuda
« Reply #4 on: May 06, 2009 - 06:42:55 PM »
Awesome! Thanks guys for the info. You never know whats hype or truth with many parts.
« Reply #5 on: May 06, 2009 - 09:38:21 PM »
73 E stroker & confederate Cuda also adapted the Hydroboost , it works great as long as you have power steering to tap the pressure from
Offline leithal
« Reply #6 on: May 06, 2009 - 10:46:48 PM »
I've had the Hydraboost system on my 71 BB Vette for 5 years now.  Once dialed in it has been trouble free and definately improved pedal feel and brake response.
Offline 73EStroker
« Reply #7 on: May 09, 2009 - 11:39:41 PM »
Mine is off a AWD Chev AstroVan. Will take pictures tomorrow (promise) both under the dash and under the hood. You can use the stock bellcrank setup that the vacuum system used. Total cost for the setup about $100 using a second hand hydraboost from the wreckers.
Barry (Salmon Arm)
« Reply #8 on: May 10, 2009 - 10:48:54 AM »
We have 6 or 7 at work but our inventory guy prices just the booster at about $150.  Thats without the master lines and brackets.
Offline 73EStroker
« Reply #9 on: May 11, 2009 - 12:47:35 AM »
Here are the pictures of my installation. I used the original bellcrank and installed a HEIM joint on hydra unit by cutting down the original plunger rod and putting a male thread on it. This aligns the plunger rod more straight into the hydra unit and reduces the pedal pressure applied (read - less of a chance of locking the wheels too easy)Don't forget the locking nut on the HEIM or the rod will turn and you will have brakes applied when you do not want them. You will need a large 1" thick aluminum block on the engine side between the booster and the firewall. The rest should be pretty much self explanatory. I will always help with any further questions.
« Last Edit: May 11, 2009 - 12:49:14 AM by 73EStroker »
Barry (Salmon Arm)
Offline go-fish
« Reply #10 on: May 16, 2009 - 09:38:43 PM »
I have Hydratech's kit. It'll put you through the windshield if you mash the brake pedal. :bigsmile:
« Reply #11 on: May 17, 2009 - 11:53:44 AM »
Lol I guess thats good to know. :roflsmiley:
Offline 73EStroker
« Reply #12 on: May 23, 2009 - 08:35:15 PM »
Mike71cuda  - you sent me an email. I have sent two replies. Let me know if you get them as my email address is on one of them.
Barry (Salmon Arm)
