Author Topic: Fuel Gauge Gremlin  (Read 832 times)
Offline ashley_j
Fuel Gauge Gremlin
« on: May 06, 2009 - 02:00:38 PM »
My second post and another gauge issue. My '73 Challenger with rallye cluster that was redone by AutoInstruments  :) has a RTE Solid State Limiter  :thumbsup: seems to have a fuel gauge issue. When I first juiced the cluster the fuel gauge seemed to read low but I was working on other things and put it down lower on my to do list. The gauge then seemed to start working and read correctly after the first fillup. Then I noticed a guage blip that made the gauge read about 1/4 lower than I thought it should. It sat for about 30 secs and return to the higher reading. This occurs regularly but not on any pattern that I can see. I have a new sending unit and ground strap. Any ideas on where to check or any checks I may have missed?  Thanks :dunno:
2009 Dodge Charger 3.5 (Son's Ride)
2008 PT Cruiser Turbo (Mom's Hotrod)
2006 Grand Caravan SXT (you'd be surprised)
1973 Dodge Challenger (383ci w/425HP)
NEVER FORGET!!!!!!!!!!!!
Re: Fuel Gauge Gremlin
« Reply #1 on: May 06, 2009 - 03:51:24 PM »
Your voltage limiter is also linked to the oil pressure and temp. gauges. So if the limiter was at fault, all three would be going crazy at the same time.
I suspect it's your sending unit. I know many people have had problems with the aftermarket units not reading correctly, but this is the first I have heard about one jumping around.
Offline ashley_j
« Reply #2 on: May 06, 2009 - 04:21:20 PM »
The other gauges are working correctly or at least consistently with no erractic behavior. I didn't think it was in the limiter but I needed a second opinion. Is their a good, in car test for the sending unit?
Offline 340_6pak
« Reply #3 on: May 06, 2009 - 05:35:12 PM »
The only test I know is with a volt-ohm meter. I do not know what the reading should be, but others on this board do.
73 Challenger
340 6pak
Offline 71 DEPUTY
  • IF YOU CAN'T DODGE IT--RAM IT!
    • Cardomain
« Reply #4 on: May 07, 2009 - 09:16:06 AM »
This is probley due to the fact that the new limiter gives you a steady 5 volts- so any float level change in the tank will reflect it faster than the old limiter as it was a pulsed voltage.  if the the other gauges are reading normal when it does this then the limiter is ok- the float is just bouncing around and maybe not setup right in the tank!
Offline 73Chally
« Reply #5 on: May 07, 2009 - 09:29:52 AM »
Is it an aftermarket sending unit?  If so, you might need to pull it out and bend it a bit so the bottom doesn't hit on the bottom of the tank.  I had to do that with mine.  You probably need to pull it anyways, because it sounds like something is rubbing or catching on the float.
Offline ashley_j
« Reply #6 on: May 12, 2009 - 12:22:54 AM »
Thanks for all the advice!!!!I have been away and have not been back to the board until today. I will look into some of the ideas as soon as I burn a little fuel. :burnout:
 :2thumbs:    :cheers:    :thumbsup:
« Reply #7 on: May 12, 2009 - 08:25:34 AM »
You state you have a new ground strap but what you describe is classic symptom of poor ground.
Double check that, maybe add a second ground & see what happens.
