Author Topic: Engine compression ratio info  (Read 661 times)
Offline BarracudaDave
« on: May 06, 2009 - 06:02:57 PM »
Just picked up an ebay reproduction operator's manual for my 70 Cuda.  Page 53 lists the engine specifications.  I was surprised to see the 340 engine listed as 10.5 to 1 compression.  I didn't think it was that high from the factory?
The other engines listed were 6 cyl at 8.4 to 1; 318 at 8.80 to 1; 383 2 barrel at 8.7 to 1; 383 4 barrel at 9.5 to 1; 426 Hemi at 10.25 to 1;  440 4 barrel at 10 to 1; and the 440 six barrel at 10.5 to 1.
Re: Engine compression ratio info
« Reply #1 on: May 06, 2009 - 08:59:34 PM »
most of those figures were under ideal circumstances  & a bit optomistic but in the right area
« Last Edit: May 12, 2009 - 01:33:36 AM by Chryco Psycho »
Offline Aussie Challenger
« Reply #2 on: May 08, 2009 - 02:17:15 AM »
  Earlier 426 Hemi engines had 11.5 :1 & I heard some were even higher.   :bigsmile:
Offline moparmaniac59
  • Drive it like ya stole it!
« Reply #3 on: May 11, 2009 - 12:18:36 PM »
As the "smog" engines came along later in the 70's the compression ratios dropped considerably. Take the '74 440 engine (no longer available in "E" bodies) as it only had an 8.2:1 Compression ratio as did the 400. The 318 dropped to 8.6:1. The six cylinder stayed at 8.4:1 and the 360 was 8.4:1.
                                                 Matt B.
Matt
Offline 71chally416
    • The Streetwalker
« Reply #4 on: May 12, 2009 - 01:52:20 AM »
Every stock early 340 I've ever seen apart has an above deck piston deck height, so the 10.5 comp number for them is probably accurate.
