Author Topic: Steering box problem  (Read 2386 times)
Offline 6packCuda
« on: May 11, 2009 - 10:02:16 PM »
I just replaced a seal in the power steering box in my Cuda. Now, when I start it up, the wheels turn all the way to one side by itself. I saw a couple of posts from people having the same problem, but the pic.s showing how to adjust it are gone. Can somebody help me out with this?
Re: Steering box problem
« Reply #1 on: May 12, 2009 - 01:43:11 AM »
there are 2 1/2 bolts that hold the housing to the top of the steering box , loosen the bolts & tap the housing uo ro down on the steering box until the wheels stay centered
Offline 6packCuda
« Reply #2 on: May 12, 2009 - 06:48:30 AM »
Are you talking about the 2 bolts where the return line goes in or the two bolts where the supply line goes in? One opens a horizontal hole, and the other opens a vertical hole with a spring loaded valve behind it.
« Reply #3 on: May 12, 2009 - 08:03:23 AM »
Something I saved
Offline 6packCuda
« Reply #4 on: May 13, 2009 - 07:30:20 AM »
Ok, I think I've got it worked out now. It's amazing how sensitive of an adjustment that is. Thanks for the input guys.
Offline Husker Cuda
« Reply #5 on: May 17, 2009 - 10:34:29 PM »
Got mine adjusted too.  Here is a scan of the page out of the service manual for this adjustment.  Hope it helps anyone else that has this problem.  Start at step 15.  If anyone needs a clearer version let me know and I can email it to you.
« Last Edit: May 17, 2009 - 10:38:52 PM by Husker Cuda »
1974 'Cuda 512 stroker 650HP Indy heads, Hemi 4 speed, pistol grip - restored to new.
1970 GTX 440/727 Y4 Gold w/ black interior
1969 Camaro SS 396 4-speed X22
1970 Chevelle SS 396 - 375HP M22 4 speed
Alaskan_TA
« Reply #6 on: May 17, 2009 - 10:38:31 PM »
From 1969, but the data is the same for this adjustment. Watching the video will help anyone understand how the whole PS system works as well. Chapter 2 at this link;
http://www.hamtramck-historical.com/MTSC/1969/ServiceConferenceMenu.shtml
Offline 6packCuda
« Reply #7 on: May 17, 2009 - 11:10:54 PM »
That's good stuff Barry. Thanks.
« Reply #8 on: May 18, 2009 - 08:04:32 AM »
Could it be......................................Sponge Bob's Grandad??
Offline Old MrB
« Reply #9 on: May 22, 2009 - 07:28:51 AM »
Looks like Gumby's rider!  And what are those NASA pilots doing to that carb!?  Could it be an Apollo mixer valve?!  :roflsmiley:
1970 Barracuda (318)
1973 Duster (360)
1984 F-250 4X4 (7.1l)
1984 MB 200
1988 Mazda 626
1993 Camry
2002 SEAT Alhambra (diesel)
2009 R/T Classic (on order)
