Author Topic: 4 alt wires  (Read 1521 times)
Offline shadango
4 alt wires
« on: May 12, 2009 - 07:54:29 AM »
Ok, so I have a bill evans wiring harness.....for teh alt it has the wire to the lug and then 3 other wires.....one bronw, one green and one dark blue.....I am using the green and blue as the alt has only two spade connectors.
What do I do with the brown (3rd) wire?
Re: 4 alt wires
« Reply #1 on: May 12, 2009 - 07:59:08 AM »
Sure it's not for the temperature  sender...My smallblock's is brown & runs with the alt.w iring. ..has a round plug.
Offline shadango
Re: 4 alt wires
« Reply #2 on: May 12, 2009 - 08:13:13 AM »
No, found that wire.....this wire is a spade connector just like the other two.....
I seem to remember a third wire on my original harness that was twisted /taped off....
Offline 71 DEPUTY
  • IF YOU CAN'T DODGE IT--RAM IT!
    • Cardomain
Re: 4 alt wires
« Reply #3 on: May 12, 2009 - 08:14:56 AM »
if correct- that is for your washer bottle pump motor!!
Re: 4 alt wires
« Reply #4 on: May 12, 2009 - 08:17:53 AM »
 :iagree: & it would be longer than the others.
Offline shadango
Re: 4 alt wires
« Reply #5 on: May 12, 2009 - 08:24:43 AM »
!!! Oh!    Well, that may make sense then...although I dont have a windshield washer pump (or bottle) right now..my car has the foot pump......I dont have any dash buttons or swiches for the pump.... ???????
Offline 71 DEPUTY
    • Cardomain
Re: 4 alt wires
« Reply #6 on: May 12, 2009 - 08:40:10 PM »
wire was there for all cars- the washer switch will not have the push to turn on the pump.- just tape it to the harness to keep it away from other stuff.
Offline shadango
Re: 4 alt wires
« Reply #7 on: May 13, 2009 - 05:05:34 PM »
Thanks!   Now, is getting an electric pump then as easy as getting an electric pump equipped washer tank (mine is toast) and the rightswitch? In other words, it is prewired obviously, eh?
Re: 4 alt wires
« Reply #8 on: May 13, 2009 - 05:30:13 PM »
Everything is available new except the wiper switch with the washer function... You will need to aquire that used or NOS...   Tanks & tubing through restoration folks, pump/motor from any parts house.
Offline shadango
Re: 4 alt wires
« Reply #9 on: May 13, 2009 - 06:12:40 PM »
Thanks!
Just found out I have a $1,000 tranny billcoming LOL so the washer tank will need to wait a while.... :eek7:
But will keep my eyes open for the switch....
