K-frame coins
Author Topic: K-frame coins  (Read 10142 times)
Offline Challenger6pak
Re: K-frame coins
« Reply #15 on: May 20, 2009 - 02:34:52 PM »
I do see it. I can only make out the 2 clearly. Maybe it is a 72 like Sadil340 has on his.
Offline autoxcuda
    • Spring Fling
Re: K-frame coins
« Reply #16 on: May 20, 2009 - 11:27:28 PM »
I was just reading the topic “Its all about the details....front suspension rebuild”
the K-frame can be seen in the first photo, it looks like a 52.
The plot thickens
 :popcorn:
It's 52. Shows up clear on my larger raw pictures that I took.
I can ask Troy if that  coin number happens to reflect the buildsheet part number.
Also, I'm pretty sure there is a date code stamped on the K-member. Troy tracked the date code on every part on that car that had a date code. More parts have date code than you might think.
Spring Fling XXX
April 22 & 23 2016
at Woodley Park Van Nuys, CA.
Special 30th Anniversary Event!
600+ Mopars, 300+ swappers,  50+ manf. midways.
Thrus: Mopar Track Day at Willow Springs Raceway
Fri: Caravan & Cruise
Sat: Mopar Cruise-In
Alaskan_TA
Re: K-frame coins
« Reply #17 on: May 20, 2009 - 11:37:11 PM »
52 is correct for T/As, AARs & 318, 340 & 383 cars after about mid-1970 model year. The 52 is on the broadcast sheets, it is the last two digits of the actual part number.
Date codes for these are stamped into the flat vertical surface on the front of the K member.
« Last Edit: May 20, 2009 - 11:38:47 PM by Alaskan_TA »
Offline sadil340
Re: K-frame coins
« Reply #18 on: May 21, 2009 - 07:30:38 AM »
That would jive with why my car has a 72 not a 52 - it was delivered in April 1970 so would have been manufactured before the mid-1970 model year.
1970 Cuda 340 4-speed
3:55 SureGrip
Owned since 1974
Bought from original owner
Offline RusTy/SE
  • Just havin' fun
Re: K-frame coins
« Reply #19 on: May 21, 2009 - 09:22:11 PM »
3449 from my car's k-frame, spd 109
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
Alaskan_TA
Re: K-frame coins
« Reply #20 on: May 21, 2009 - 09:29:00 PM »
3449 - 344th day of 1969 (1970 model year)
Re: K-frame coins
« Reply #21 on: May 22, 2009 - 10:01:12 PM »
Thanks for the responses. This has been great! It will help to identify what should be on a car. With a buildsheet it could identify if the K-frame has been changed.
Barry, how much of a time period could there be between the fender tag date and the K-frame date?
Alaskan_TA
Re: K-frame coins
« Reply #22 on: May 22, 2009 - 10:32:53 PM »
Fender tag dates can be up to three weeks or so off, either early or late.
K-frame dates? I have not looked into it, I just do not go around comparing them.  :dunno:
For the guys into the date code thing, you should start a spreadsheet for any items you KNOW are original to the car. I need to do that myself for my T/A one of these days. So far, my engine assembly date is a few days after the date on the fender tag, so I know my car was made "late".
Offline autoxcuda
    • Spring Fling
Re: K-frame coins
« Reply #23 on: May 23, 2009 - 02:51:39 AM »
I think Troy with the brown T/A has a list of all his date codes.
Spring Fling XXX
April 22 & 23 2016
