Mike-
I believe the "extra hole" really is just extra, my Magnumforce spindles don't have it either. Your calipers will work just fine, providing they're the same type as the Cordoba. Ma Mopar made two (well more, but for our application 2) types of calipers, the pin type and the slider type. If the Cordoba caliper brackets are the pin type, you're probably in luck as that's what most of the E-body's had. If it had the slider type, you'll need a set of calipers off an A or B body. The calipers are basically the same for each type, just the mounting is different. The slider kind is a slightly stronger design, and is preferred by the racer types, but its unlikely to make any difference at all on a street car.
Here's a picture of my spindles (no extra hole!) and a set of pin type 11 3/4" rotor caliper brackets...
This is a picture of the slider type
