Author Topic: Anyone have fit problems with new rear glass???  (Read 873 times)
Offline HemiOrange70
« on: May 14, 2009 - 01:41:11 PM »
As my saga continures.....My new rear glass doesn't fit. Measured it up with the old and it is 1/4" narrower and 1/8" less in height. Anyoneelse have these troubles?
Re: Anyone have fit problems with new rear glass???
« Reply #1 on: May 15, 2009 - 01:13:30 AM »
I dont have your problem, but it seems like it should still fit easy enough.  1/8 inch on each side and 1/16th top to bottom will not be noticed
« Reply #2 on: May 15, 2009 - 12:11:19 PM »
I thought so too, but it was way off as per my bodyguy and the glass guys
Offline E-Body Products
  • E-Body Products
    • E-BODY PRODUCTS
« Reply #3 on: May 15, 2009 - 09:48:56 PM »
Are you using the the tabs at the bottom to support the rear glass?  This helps center the rear glass vertically in the window opening.  You probably are, but I thought I would throw it out there.
Daniel
www.ebodyproducts.com
dj1965@ebodyproducts.com
www.stantek-us.com
Offline DMZ73
    • http://www.pbase.com/dmz73/
« Reply #4 on: May 16, 2009 - 11:10:05 AM »
DId you replace any of the surround or roof skin?
Maybe the allignment is a little off on the sheetmetal.... :clueless: :dunno:
Dan
Offline 73Chally
« Reply #5 on: May 16, 2009 - 12:09:33 PM »
If the fit is that far off, then I would say the glass itself is wrong.  Have you tried another piece?
« Reply #6 on: May 17, 2009 - 12:53:09 PM »
The roof skin was never touched....the old glass fits fine and the new is off. It is smaller than the original. Trying to get a resolve. The more I do the more backwards I am getting :pullinghair:
Offline quapman
    • Auto-Grip on Facebook
« Reply #7 on: May 17, 2009 - 06:47:10 PM »
I would suggest using the rubber jack blocks that come with the windshield seal (3M supplies them) to support the glass rather than the metal clippy things. I just put a used back glass in my Challenger and the blocks centered it up just right. The clippies would have been a good 3/16" too low.
I noticed that the side gaps are pretty big once it's in, but I got a good seal anyway. (I DID have to add a little extra seal to the sides, toward the bottom.)
I left the paper on the seal and set the glass in place to check for a consistent seal before getting crazy and sticking it in permanently. Removed glass, added extra stickum, re-applied paper strips, test fit again, etc.
It's an easy job, but then again......not really.   :)
Offline femtnmax
« Reply #8 on: May 17, 2009 - 09:05:04 PM »
What 3M part number seal do you recommend??   Maybe age old question, but I wanted the latest info.  thank you.
Phil
Offline quapman
« Reply #9 on: May 17, 2009 - 09:21:52 PM »
I keep forgetting to bring the package in from the shop as I also promised that number in another thread. I do know that it's 3/8 ribbon seal.
Offline quapman
« Reply #10 on: May 18, 2009 - 06:31:54 PM »
O.K. here it is........
3M Windo-Weld Ribbon Sealer (Round Bead, 3/8" X 15')
Part # 051135 08612
