Author Topic: Fuel and watergauge doesn't work  (Read 535 times)
Offline Belgium Cuda
  • Living in Belgium but beeing Swedish
« on: May 15, 2009 - 02:54:56 PM »
I tested both sendingunits so I guess that's leaves the voltagelimiter? It's a -70 non rally, I grounded
the wires to fuel and watergauge but nothing happens. Where can I buy a new limiter if that's the problem?
1970 Challenger Convertible - to become a Hemi tribute
1968 Charger R/T 500 cui stroker
Offline willard
    • 1970 Challenger R/T
Re: Fuel and watergauge doesn't work
« Reply #1 on: May 16, 2009 - 02:08:21 AM »
try RT engeneering (http://www.rt-eng.com/mediawiki/index.php/Main_Page) or make one yourself ;) at allpar.com there's a simple guide on how to make a solid state VL.
1970 383 R/T SE
« Reply #2 on: May 16, 2009 - 02:10:49 AM »
you need to check voltage into the guage , the problem could be the guage itself or the voltage limiter , so you need to test for pulsing 5V feed to the the guages from the limiter , if you are getting 5V out of the limiter to the guage the guage is bad .
« Reply #3 on: May 16, 2009 - 03:48:59 PM »
Thanks for the input. :thumbsup:
